Power Use
Shonk
I have a second brand new Microserver Gen8 that's coming into service
as i upgrade it im going to document its power use for myself
maybe people will find this info interesting so will post here
at the moment its just setup with the boot drive my spare 2gb stick from my other gen8 and a clean install of windows 10 pro
In the future it will have an E3-1230v2 upwards fitted (depending what comes along cheap)
16gb of ram boot 2.5" replaced with ssd more hd's etc
as things go in i will update this thread
Next time i have my Main Gen8 down i will test its power use also
EU 200W PSU
Intel® Celeron® CPU G1610T @ 2.30GHz
2 x 2GB HP DDR3 1600 @ 1333
1      Good, In Use     HP SmartMemory      669237-071      DIMM DDR3     2048 MB     1600 MHz     1.5 V     1     UDIMM
2      Good, In Use     HP SmartMemory      669237-071      DIMM DDR3     2048 MB     1600 MHz     1.5 V     1     UDIMM
1 x 7200 RPM 2.5" Seagate ST320LT007 Momentus THIN 320 GB
1 x 32gb Samsung Micro SD
3 x Gigabit Ethernet
AHCI Mode
CPU OS Controlled
Powered down 5w/6w
Idle in windows 21w/22w
CPU Fully Loaded 34w/35w (Prime 95 in-place large FFTS)
Idle in windows Marvell 9230 24w/25w
Idle in windows HP LSI 9217-4i4e (LSI SAS2308) 30w/31w
To Surmise
Marvell 9320 adds 3w (No Connected Devices)
LSI SAS2308 adds 9w (No Connected Devices)
13w difference between load and idle
Things to remember when in an idle state in windows
cpu is idle, ram is idle,north bridge is idle, south bridge is idle
prime 95 should load atleast the cpu/ram/north bridge
so of that 13w difference at a stab
7w or so will be cpu under load
3w or so will be ram under load
3w or so will be bridge's under load
Edited by Shonk
I run 4x seagate NAS drives + 1x intel x-25-v 40gb SSD + i3 3240t and draw 43 watts idle at the wall with whs I can't get the thing to draw more than 90w at the wall with synthetic benchmarks,
I have the Xeon version - E3-1220L v2, 8GB of RAM, MSI N210-MD1GD3H/LP video card (it's connected to the TV), Windows 2012 Server on a Kingston V300 120GB and 4 HDDs: Seagate SV35 2TB & 3TB, WD 30PURX and HGST Ultrastar 7K4000 4TB. I use this thing as a NAS/torrent box/media player. While it's idle in Windows (if you can call "idle" seeding almost 400 torrents) the power usage is around 50 to 60 watts. The peak usage is somewhere around 110 watts, but I've yet to find out when/where. I don't use it for anything "thirsty" at the moment and during the boot procedure the max. usage usually goes up to around 70-80 watts.
Added a few things today (New are in bold)
Sitting in windows drives still spinning
40w/41w
Drives spun down after set idle time
27w/28w
EU 200W PSU
2 x 8GB DDR3 1600 @ 1333
AHCI Mode
CPU OS Controlled
Port 0 Samsung EVO 850 250GB
Port 1 Samsung HD501LJ 7200 RPM
Port 2 Empty
Port 3 Empty
Port 4 Seagate ST3000DM001 7200 RPM
Marvell 9230
Port 0 Empty
Port 1 Empty
Port 2 Hitachi HTS543232A7A384 (5400 RPM 2.5")
Port 3 Seagate Momentus Thin (7200 RPM 2.5") (Old Boot Drive)
Edited by Shonk
Something interesting i just noticed on Windown 10 Pro atleast
RDP in 27/28w
RDP Closed 33w/34w
iLO Remote signed in 27/28w
iLO Closed 27/28w
There's something eating 6w if you leave an rdp session logged in but disconnected
the second you remote in with ilo and log in to the desktop it drops to 27w/28w
the same with rdp
the second you close rdp it goes back up to 34w
after a few mins of closing iLO it goes back to 34w
as soon as windows thinks the pc is idle its upto something
thats eating 6w
This isnt anti malware as its disabled by polcy
Shouldnt be cortana as thats blocked and disabled
all drives where defraged an hour or so ago
Edited by Shonk
as soon as you close rdp etc..
system and compressed memory starts using the cpu at 100% load
interesting must look into what ms are upto im sure its no good
Took screenshot at 35:01 Cpu time
Closed RDP for 60 seconds (stopwatch)
Took screenshot 36:04 Cpu time
http://s18.postimg.org/od1ag4ps9/image.jpg
Edited by Shonk
Whatever it is that it's doing, it will settle down once it's finished. I'm a bit surprised to see compressed memory kicking in for a machine with 16GB RAM. Have you changed a lot of the defaults (you mentioned you disabled anti-malware in group policy)?
It does seem to have settled down it ended up with about 3 hours of cpu time then stopped
with regards changes
Win10Tweak.cmd
rem disable quick access
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /f /v "LaunchTo" /t REG_DWORD /d 0 > NUL 2>&1
rem show file extensions
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v "HideFileExt" /t REG_DWORD /d 0 /f > NUL 2>&1
rem disable lock screen
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Personalization" /v "NoLockScreen" /t REG_DWORD /d 1 /f > NUL 2>&1
rem enable classic control panel
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" /v "ForceClassicControlPanel" /t REG_DWORD /d 1 /f > NUL 2>&1
rem disable windows update sharing
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" /v "DownloadMode" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" /v "DODownloadMode" /t REG_DWORD /d 0 /f > NUL 2>&1
rem Remove telemetry and data collection
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Device Metadata" /v PreventDeviceMetadataFromNetwork /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\DataCollection" /v "AllowTelemetry" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\MRT" /v DontOfferThroughWUAU /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\SQMClient\Windows" /v "CEIPEnable" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\AppCompat" /v "AITEnable" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\AppCompat" /v "DisableUAR" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\DataCollection" /v "AllowTelemetry" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!dss-winrt-telemetry.js" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!proactive-telemetry.js" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!proactive-telemetry-event_8ac43a41e5030538" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!proactive-telemetry-inter_58073761d33f144b" /t REG_DWORD /d 0 /f > NUL 2>&1
rem Apply Internet Explorer 11 tweaks
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "DoNotTrack" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "Search Page" /t REG_SZ /d "http://www.google.co.uk" /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "Start Page Redirect Cache" /t REG_SZ /d "http://www.google.co.uk" /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "DisableFirstRunCustomize" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceHasShown" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceComplete" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" /v "DisableFirstRunCustomize" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceHasShown" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceComplete" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\Software\Policies\Microsoft\Internet Explorer\Main" /v "DisableFirstRunCustomize" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\Software\Policies\Microsoft\Internet Explorer\Main" /v "RunOnceHasShown" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\Software\Policies\Microsoft\Internet Explorer\Main" /v "RunOnceComplete" /t REG_DWORD /d 1 /f > NUL 2>&1
rem Disable Cortana, Bing Search and Searchbar
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Windows Search" /v "AllowCortana" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Search" /v "CortanaEnabled" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Search" /v "SearchboxTaskbarMode" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Search" /v "BingSearchEnabled" /t REG_DWORD /d 0 /f > NUL 2>&1
rem Disable Windows Error Reporting
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Windows Error Reporting" /v "Disabled" /t REG_DWORD /d 1 /f > NUL 2>&1
rem Disable Hibernation
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Power" /v "HiberbootEnabled" /t REG_DWORD /d 0 /f > NUL 2>&1
rem Disable tracking services
sc config DiagTrack start= disabled > NUL 2>&1
sc config diagnosticshub.standardcollector.service start= disabled > NUL 2>&1
sc config TrkWks start= disabled > NUL 2>&1
sc config WMPNetworkSvc start= disabled > NUL 2>&1
sc config DoSvc start= disabled > NUL 2>&1
rem Disable WAP Push Message Routing Service
sc config dmwappushservice start= disabled > NUL 2>&1
rem Disable Windows Search
sc config WSearch start= disabled > NUL 2>&1
del "C:\ProgramData\Microsoft\Search\Data\Applications\Windows\Windows.edb" /s > NUL 2>&1
rem Disable Security Center
rem sc config wscsvc start= disabled > NUL 2>&1
rem Disable Geolocation Service
sc config lfsvc start= disabled > NUL 2>&1
rem shonk
SC stop dmwappushsvc
SC stop diagtrack
SC delete dmwappushsvc
SC delete diagtrack
sc delete DiagTrack
sc delete dmwappushservice
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\DataCollection" /v AllowTelemetry /t REG_DWORD /d 0 /f
rem Disable Windows Defender
sc config WinDefend start= disabled > NUL 2>&1
sc config WdNisSvc start= disabled > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows Defender" /v "DisableAntiSpyware" /t REG_DWORD /d 1 /f > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Cache Maintenance" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Cleanup" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Scheduled Scan" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Verification" /Disable > NUL 2>&1
del "C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache*" /s > NUL 2>&1
rem Disable unnecessary scheduled tasks
schtasks /Change /TN "Microsoft\Windows\AppID\SmartScreenSpecific" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Customer Experience Improvement Program\Consolidator" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Customer Experience Improvement Program\KernelCeipTask" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Customer Experience Improvement Program\UsbCeip" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\DiskDiagnostic\Microsoft-Windows-DiskDiagnosticDataCollector" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\NetTrace\GatherNetworkInfo" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Error Reporting\QueueReporting" /Disable > NUL 2>&1
schtasks /Change /TN "\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser" /Disable > NUL 2>&1
schtasks /Change /TN "\Microsoft\Windows\Application Experience\ProgramDataUpdater" /Disable > NUL 2>&1
schtasks /Change /TN "\Microsoft\Windows\Application Experience\StartupAppTask" /Disable > NUL 2>&1
schtasks /Change /TN "\Microsoft\Windows\Customer Experience Improvement Program\Consolidator" /Disable > NUL 2>&1
schtasks /Change /TN "\Microsoft\Windows\Customer Experience Improvement Program\KernelCeipTask" /Disable > NUL 2>&1
schtasks /Change /TN "\Microsoft\Windows\Customer Experience Improvement Program\UsbCeip" /Disable > NUL 2>&1
schtasks /Change /TN "\Microsoft\Windows\Windows Error Reporting\QueueReporting" /Disable > NUL 2>&1
schtasks /Change /TN "\Microsoft\Windows\WindowsUpdate\sih" /Disable > NUL 2>&1
rem Remove windows default apps
powershell "Get-AppxPackage *3d* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *bing* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *zune* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *photo* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *communi* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *solit* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *phone* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *soundrec* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *camera* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *people* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *office* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *xbox* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *Candy* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *Twitter* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *MicrosoftEdge* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *DVDPlayer* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *WindowsMaps* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *SkypeApp* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *Skype* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *Office* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *WindowsPhone* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *ASUSWelcome* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *ConectivityStore* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *Messaging* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *WindowsFeedback* | Remove-AppxPackage" > NUL 2>&1
rem shonk
powershell "get-appxpackage -AllUsers -Name Microsoft.3DBuilder                     | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.Getstarted                    | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.MicrosoftOfficeHub            | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.MicrosoftSolitaireCollection  | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.SkypeApp                      | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.WindowsMaps                   | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.BingWeather                   | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.Office.OneNote                | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.BingSports                    | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.BingNews                      | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.WindowsPhone                  | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.BingFinance			| remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.ZuneMusic                     | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.ZuneVideo                     | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.ConnectivityStore                    | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name Microsoft.Messaging                    | remove-appxpackage"
powershell "get-appxpackage -AllUsers -Name WindowsFeedback                   | remove-appxpackage"
powershell "Remove-AppxPackage Microsoft.Windows.Cortana_1.4.8.176_neutral_neutral_cw5n1h2txyewy"
powershell "Remove-AppxPackage -Package Microsoft.3DBuilder_10.1.9.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.BingWeather_4.4.200.0_x86__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.BingFinance_4.4.200.0_x86__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.BingSports_4.4.200.0_x86__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.BingNews_4.4.200.0_x86__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.Getstarted_2.2.7.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.Office.OneNote_17.4229.10061.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.MicrosoftOfficeHub_17.6020.23801.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.WindowsMaps_4.1506.50715.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.SkypeApp_3.2.1.0_x86__kzf8qxf38zg5c"
powershell "Remove-AppxPackage -Package Microsoft.Windows.Photos_15.721.12350.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.ZuneMusic_3.6.11821.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.ZuneVideo_3.6.11821.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.People_1.10241.0.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package microsoft.windowscommunicationsapps_17.6020.42011.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.WindowsCamera_5.42.3006.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.WindowsPhone_10.1507.17010.0_x64__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package Microsoft.Messaging_1.10.22012.0_x86__8wekyb3d8bbwe"
powershell "Remove-AppxPackage -Package WindowsFeedback_cw5n1h2txyewy"
rem Disable OneDrive
reg add "HKLM\Software\Policies\Microsoft\Windows\OneDrive" /v DisableFileSyncNGSC /t REG_DWORD /d 1 /f > NUL 2>&1
rem Block Windows telemetry servers
copy "%WINDIR%\system32\drivers\etc\hosts" "%WINDIR%\system32\drivers\etc\hosts.bak" > NUL 2>&1
attrib -r "%WINDIR%\system32\drivers\etc\hosts" > NUL 2>&1
FIND /C /I "vortex.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 vortex.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "vortex-win.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 vortex-win.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telecommand.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telecommand.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telecommand.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telecommand.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "oca.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 oca.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "oca.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 oca.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "sqm.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 sqm.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "sqm.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 sqm.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "watson.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 watson.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "watson.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 watson.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "redir.metaservices.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 redir.metaservices.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "choice.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 choice.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "choice.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 choice.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "reports.wes.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 reports.wes.df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "services.wes.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 services.wes.df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "sqm.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 sqm.df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "watson.ppe.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 watson.ppe.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.appex.bing.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.appex.bing.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.urs.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.urs.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.appex.bing.net:443" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.appex.bing.net:443>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "settings-sandbox.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 settings-sandbox.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "vortex-sandbox.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 vortex-sandbox.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
attrib +r "%WINDIR%\system32\drivers\etc\hosts" > NUL 2>&1
:finish
CLS
ECHO.
ECHO Installation complete.
ECHO Press any key to exit.
PAUSE > NUL
Win10Tweak.reg
; Command Prompt
Windows Registry Editor Version 5.00
[-HKEY_CLASSES_ROOT\Directory\shell\cmd]
[-HKEY_CLASSES_ROOT\Directory\shell\runas]
[HKEY_CLASSES_ROOT\Directory\shell\runas]
@="Open command prompt"
"HasLUAShield"=""
[HKEY_CLASSES_ROOT\Directory\shell\runas\command]
@="cmd.exe /s /k pushd \"%V\""
[HKEY_CLASSES_ROOT\Directory\Background\shell\runas]
"HasLUAShield"=""
[HKEY_CLASSES_ROOT\Directory\Background\shell\runas\command]
[HKEY_CLASSES_ROOT\Drive\shell\runas]
"HasLUAShield"=""
[HKEY_CLASSES_ROOT\Drive\shell\runas\command]
[-HKEY_CLASSES_ROOT\Directory\Background\shell\cmd]
[-HKEY_CLASSES_ROOT\Directory\Background\shell\runas]
[-HKEY_CLASSES_ROOT\Directory\background\shell\cmd]
[-HKEY_CLASSES_ROOT\Directory\background\shell\cmd\command]
[-HKEY_CLASSES_ROOT\Drive\shell\cmd]
[-HKEY_CLASSES_ROOT\Drive\shell\runas]
;disable onedrive
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Onedrive]
"DisableLibrariesDefaultSaveToOneDrive"=dword:00000001
"DisableFileSync"=dword:00000001
"DisableMeteredNetworkFileSync"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Policies\Microsoft\Windows\Onedrive]
[HKEY_CLASSES_ROOT\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}\ShellFolder]
"Attributes"=dword:f090004d
[HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}\ShellFolder]
[HKEY_CURRENT_USER\Software\Classes\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}\ShellFolder]
[HKEY_CURRENT_USER\Software\Classes\Wow6432Node\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}\ShellFolder]
; Disable Lan Security Check
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Internet Explorer\Security]
"DisableSecuritySettingsCheck"=dword:00000001
;Search Provider
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment]
"DEVMGR_SHOW_NONPRESENT_DEVICES"="1"
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes]
"DefaultScope"="{6FEFF4C3-F6DB-438F-824F-C6480B672CE9}"
"Version"=dword:00000004
"UpgradeTime"=hex:46,f9,11,38,35,42,d0,01
"KnownProvidersUpgradeTime"=hex:e3,7d,92,e1,d8,df,ce,01
"DefaultPackCorrection"=dword:00000001
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}]
"Deleted"=dword:00000001
"TopResultURLFallback"="http://www.bing.com/search?q={searchTerms}&src=IE-TopResult&FORM=IE11TR"
"SuggestionsURLFallback"="http://api.bing.com/qsml.aspx?query={searchTerms}&maxwidth={ie:maxWidth}&rowheight={ie:rowHeight}&sectionHeight={ie:sectionHeight}&FORM=IE11SS&market={language}"
"FaviconURLFallback"="http://www.bing.com/favicon.ico"
"FaviconPath"="C:\\Users\\Shonk\\AppData\\LocalLow\\Microsoft\\Internet Explorer\\Services\\search_{0633EE93-D776-472f-A0FF-E1416B8B2E3A}.ico"
"DisplayName"="Bing"
"URL"="http://www.bing.com/search?q={searchTerms}&src=IE-SearchBox&FORM=IE11SR"
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{6FEFF4C3-F6DB-438F-824F-C6480B672CE9}]
"DisplayName"="Google"
"URL"="http://www.google.com/search?q={searchTerms}"
"Codepage"=dword:0000fde9
"OSDFileURL"="https://www.google.com/homepage/search/js/google.xml"
"FaviconURL"="http://www.google.com/favicon.ico"
"FaviconPath"="C:\\Users\\Shonk\\AppData\\LocalLow\\Microsoft\\Internet Explorer\\Services\\search_{6FEFF4C3-F6DB-438F-824F-C6480B672CE9}.ico"
"TopResultURLFallback"=""
"SuggestionsURLFallback"="http://clients5.google.com/complete/search?hl={language}&q={searchTerms}&client=ie8&inputencoding={inputEncoding}&outputencoding={outputEncoding}"
"FaviconURLFallback"="http://www.google.com/favicon.ico"
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{6FEFF4C3-F6DB-438F-824F-C6480B672CE9}\Non-Matches]
"http://www.google.com/homepage/search/js/google.xml"=hex:80,9e,7d,36,76,10,cd,\
  01
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Desktop\NameSpace\DelegateFolders\{F5FB2C77-0E2F-4A16-A381-3E560C68BC83}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Explorer\Desktop\NameSpace\DelegateFolders\{F5FB2C77-0E2F-4A16-A381-3E560C68BC83}]
; Remove Desktop From This PC
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}]
; Remove Documents From This PC
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A8CDFF1C-4878-43be-B5FD-F8091C1C60D0}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{d3162b92-9365-467a-956b-92703aca08af}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A8CDFF1C-4878-43be-B5FD-F8091C1C60D0}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{d3162b92-9365-467a-956b-92703aca08af}]
; Remove Downloads From This PC
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{374DE290-123F-4565-9164-39C4925E467B}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{374DE290-123F-4565-9164-39C4925E467B}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}]
; Remove Music From This PC
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{1CF1260C-4DD0-4ebb-811F-33C572699FDE}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3dfdf296-dbec-4fb4-81d1-6a3438bcf4de}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{1CF1260C-4DD0-4ebb-811F-33C572699FDE}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3dfdf296-dbec-4fb4-81d1-6a3438bcf4de}]
; Remove Pictures From This PC
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3ADD1653-EB32-4cb0-BBD7-DFA0ABB5ACCA}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{24ad3ad4-a569-4530-98e1-ab02f9417aa8}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3ADD1653-EB32-4cb0-BBD7-DFA0ABB5ACCA}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{24ad3ad4-a569-4530-98e1-ab02f9417aa8}]
; Remove Videos From This PC
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A0953C92-50DC-43bf-BE83-3742FED03C9C}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{f86fa3ab-70d2-4fc7-9c99-fcbf05467f3a}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A0953C92-50DC-43bf-BE83-3742FED03C9C}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{f86fa3ab-70d2-4fc7-9c99-fcbf05467f3a}]
Lots of information here, but it does seem to me that a lot of time is spent to save $5 a month.
