anyone using onedrive with whs2011
capall
Just installed OneDrive last week on my newly built WHS 2011 server!
I cheat - I copy my local network files TO the OneDrive USB drive, which I force-sync via ROBOCOPY!
That way, I have My Documents sync'd to a local USB drive (that can be taken to the PC I'm using if the spit hits the fan), which is then copied out to OneDrive!
I sync manually once a week, but, it could be scheduled to make it automatic!
No errors, no issues, no BS!
I might like to try this.  Working good for you?  I'm not familiar with ROBOCOPY but will look into it.  How would you make it automatic to copy to OneDrive?
This is my CMD file to start the forced sync :
@echo off
echo My Documents > USB > OneDrive
echo.
robocopy "e:\shares\my documents\." "o:\OneDrive" /mir /v /xf ".849C9593-D756-4E56-8D6E-42412F2A707B" /log:"OneDrive Copy.LOG"
exit
Launch, then wait for OneDrive to finish the sync upload.....
The /xf line (eXclude File) only targets the OneDrive directory, that does NOT need to be sync'd.
E: is a SATA hard drive, O: is my 16GB flash drive with my local copy of all uploaded to OneDrive!
I then log the entire transaction to be able to review it each time for issues!
