POE Switches
Dave
schoondoggy
ubiquity makes a nice system for that, seems lots less trouble than trenching and pulling.. thanks for the suggestion.
Ubiquiti and Engenius offer good affordable point to point outdoor solutions. You need clear line of sight and a stable mounting location. Be sure to check actual throughput to be sure it will meet your needs.
  • Replies 33
  • nrf
    10
  • schoondoggy
    5
  • snapper
    4
  • LoneWolf
    4
Popular Posts
I'm not an expert in this area but in my research there are at least 3 types of poe, 'proprietary' where you are stuck with the vendor's equipment, the original POE, and POE+. I suggest careful readin
Best bang for buck I've found (and I've had a lot of PoE switches in my lab ) is the Netgear GS110TP - 8 PoE 802.3f ports and 2 SFP ports for uplinks. Gigabit throughout and has nice features such a
I have two PoE switches:   1) Netgear GS110TP.  I brought this to the HSS meetup for my network config.  802.3f, fully managed 10-port gig switch.  It's small, price is right, and has a lifetime war
LoneWolf
what is benefit of a short fiber interconnect? I have a possible future use for a fiber between main house and an out-building but I would not think of it for two items on the same rack.
Personally, I probably wouldn't use fiber for less than a 3-meter connection.  If you were asking due to the pictures I had, those switches won't be on top of each other for any more than a lab configuration.  The fiber patch cables there are 20-25m, and the switches will be on different floors of the house.  Honestly, uplink via Cat5E+ would be fast enough at that distance; the fiber cables were cheap used, so I'm doing it "because I can". :D
LoneWolf
pulling fiber seems to be a tricky operation. too bad they haven't come up with super strength fiber wrapper/cover materials.  Do you recommend use of a 'lubricant'? sounds icky...
They actually do have heavy wrapper materials at least for within buildings.  I've seen it used when running fiber between floors.
If you're doing outdoor, there are special gels for pulling cable.  These are also used in armor, outdoor rated Ethernet cable too. The gel isn't just for friction; it's to prevent cable from freezing or cracking in the cold.
http://www.polywater.com/icefree.html
The outdoor-rated Ethernet able I've worked with (it hasn't been much, several people at work have had far more experience) the lubricant is kind of like a greasy Chapstick.  Outer heavy jacket.  Underneath, the sheathing was a metal that in tube form, was almost as tough as a 22 shell.  Then another cable sheath followed by the Ethernet pairs in lubricant.
And yes, it's kind of icky when terminating it, but I've done worse. For me, it was more trying to work with it on a 16' ladder, as it had been run on poles from one building to another, while trying to cut through the jacket with tools that weren't completely suited for the job.  Plus, the white pairs of this particular cable weren't striped; I realized this after separating the pairs once, muttering something I won't print, then stripping a bit more so I could figure out which wire was which.
Edited by LoneWolf
brings back memories of 'icky pic' cables from my days working for the monopoly known as 'ma bell'
