POE Switches
Dave
interesting. where would one get a cable like the one in the picture? I have 4 sfp slots waiting to serve in my T1600G-28TS .... :)
  • Replies 33
  • nrf
    10
  • schoondoggy
    5
  • pcdoc
    4
  • snapper
    4
Popular Posts
I'm not an expert in this area but in my research there are at least 3 types of poe, 'proprietary' where you are stuck with the vendor's equipment, the original POE, and POE+. I suggest careful readin
Best bang for buck I've found (and I've had a lot of PoE switches in my lab ) is the Netgear GS110TP - 8 PoE 802.3f ports and 2 SFP ports for uplinks. Gigabit throughout and has nice features such a
I have two PoE switches:   1) Netgear GS110TP.  I brought this to the HSS meetup for my network config.  802.3f, fully managed 10-port gig switch.  It's small, price is right, and has a lifetime war
schoondoggy
The copper cable with SFP's attached that GotNoTime is referring to, tend to be shorter than 10M and look like this:
The cable in LoneWolf's picture is traditional 50 or 62.5 micron multi-mode fiber with LC connections and separate SFP's. How far do you need to go? What are you connecting to?
So those short ones aren't really using fiber rather pretend to using copper for a short run....
my application would be to connect to another switch in a barn about 400 feet away, it would be 1gb only.
Edited by nrf
If there is any risk of a potential difference in the voltage between the two buildings (e.g. different earthing systems, different supply phases) then I would use fibre to avoid letting the magic smoke out.
Whilst a gigabit port will have an isolation transformer, there will be a limit to the amount of potential difference it can absorb.
other thing to remember that copper ethernet is only specced up to 100m, so 400ft is out of spec anyway...
Nice switches.  I looked up the price of the CISCO and was less than I would have thought.  Will have to look at that one in the future if my needs grow.
I have both as well and for the price (especially used) they are great.
I prefer the SG300 though as it allows copper or SFP for ports 9 & 10, but the GS110TP is SFP only.
A nice thing about the Cisco is the CLI is close to Cisco IOS, so I didn't have to learn a new syntax
schoondoggy
You could bury conduit from the house to the barn and run fiber through it. Test the cable with your switches prior to burying it. Run two nylon twine with a weight on it to get the first pull in prior to burying. After burying the conduit, pull the fiber and another nylon twine through. Be careful not to get any kinks in the fiber. There are deals on fiber on ebay. Just be sure they are LC connector and multimode.
http://www.ebay.com/itm/125M-Armored-cable-LC-LC-62-5-125-Duplex-Fiber-Patch-Cord-Jumper-LC-to-LC-MM-/262221641482?hash=item3d0da0b70a:g:7gUAAOSw~OdVVZUX
http://www.ebay.com/itm/125M-OUTDOOR-ARMORED-LC-LC-2-STRAND-OM3-50-125-MULTIMODE-FIBER-OPTIC-CABLE-10GB-/201407612328?hash=item2ee4d445a8:g:GMQAAOSwgQ9Vzbbv
Check with your switch manufacturer to see if they have recommended SFP.
pulling fiber seems to be a tricky operation. too bad they haven't come up with super strength fiber wrapper/cover materials.  Do you recommend use of a 'lubricant'? sounds icky...
ubiquity makes a nice system for that, seems lots less trouble than trenching and pulling.. thanks for the suggestion.
schoondoggy
It's not bad, just need to be careful. They have armored fiber that can been run underground without conduit, but it is very pricey.
