MCE & WHS 2011 problem with Video Playback
mailman1988
I have a problem that started a few day's ago.
1st my ISP-Comcast kept cutting in and out. Many hours of work with the tech's seamed to fix it (after many day's of trial and error).
Then I performed an update to Drive Bender to v. 2.4.0.0, Which, for some reason, had me uninstall 2.3.x (which than lost my Pool). After installing the update and performing a lot searching around for solutions, I got my Pool back (This part, I hope). All the data, folders, and files seam to be just fine.
I also believe that I might have a problem with my D-Link 8port Switch. An intermittent problem of zero packs transfer. For this I called D-Link and they are sending me a replacement. However, I don't know if this is related, as I have a 2nd 5 port D-Link switch that I have both my MCE & WHS connected to. The Flow chart is: Cable Modem, to Router, to 5 port, (WHS&MCE) than 8 port.
The 5 port does not seam to have any issues.
Here is where the problem starts.
I have Win7 Media Center on 3 PC's, this issues happens on all 3.  After my snafu with Drive Bender & the Cable Modem, I cannot play Video files through MCE. At first the PC's could not find the Library (Video). So I deleted the Library (Under MCE set up). Than try to re-find and link them. MCE had a lot of difficulty finding the server's libraries. It would spin and spin. Eventually finding them after many minutes. On one machine, I had to manually type in the link.
So now MCE can find the Video Library on the server, but takes a long time to load the individual files. When I go and select a video and click. Nothing happens. It can take 5 or more minutes to play, if at all.
Now if I minimize MCE and use explorer to find and click play, no issues and files play nicely.
What I don't know is where to isolate the problem. Could it be Drive Bender (Reports Healthy), my D-Link, again the 5 port is working fine. Could it be a Windows Update (there have been quite a few in the last week), WHS 2011, or MCE.
Looking forward to any helps.
ps:Before Last week, everything was working fine.
Sounds to me like it could be a problem with the 5 port switch, Further testing is needed. From the computer connected to the same switch as WHS 2011 open a command prompt and type "ping then the IP address of WHS 2011 and press enter, example ping 192.168.1.100 Please post the stats of the test.
It turns out that the issue was the 8 port switch. After I replaced it and reloaded the WHS Connector. All is working as it should. Even faster now.
Guess I jumped the gun on posting before I tried a replacement switch.
Thanks for your help
Glad you got it sorted out.
