Ubiquiti UniFi Users?
oj88
I have a Ubiquiti UAP-LR. I've never gone with more than one because I still don't feel it's the perfect AP. The price was right, and it seems to work pretty well, but I hate the app, and the PoE they use is not normal PoE so I could not use my PoE switch to power it. I originally had the controller software installed on my WHS2011 box, but the logs were filling up my C drive. You can't change where these go, at least you could not the last time I looked at it.
  • Replies 29
  • oj88
    9
  • snapper
    4
  • GotNoTime
    4
  • RobbieH
    2
Popular Posts
Just usage stats really. The controller is a bit of a misnomer as its really just a config and monitoring tool. If you want to run a portal on there (e.g. paying guests) then the controller needs to
The mobile app requires a minimum firmware version on the AP to work. As you're getting this AP from eBay, it may have a very old version of firmware on it. You can upgrade via SSH or just install the
Odd. It shouldn't abruptly stop forwarding traffic and the CPU is capable of running the AP at maximum load. It sounds like buggy firmware to me.  I'd still advise you to shift as much as possible o
GotNoTime
The plain UAP and UAP-LR only supported 24V passive PoE. The newer ones such as the UAP Pro are standard 802.3af PoE. Some require 802.3at for extra power.
Ubiquiti did sell a 802.3af PoE adapter to work with their 24V passive PoE UAPs. No idea if they still do. Extra box you need to deal with though.
It came with a power injector, but like you said it's an extra box and piece of equipment I have to deal with. Not very elegant, that's for sure. :)
This is probably how Ubiquiti is controlling their products' intended market.
I figure that for most home installations, which are still predominantly a non-POE environment, I guess the non-standard power injector shouldn't be a nuisance. I would think that the UAP-AC and UAP-AC-LR are more for the SOHO and residential users where there's only an average of 1-3 deployed APs.
The PRO and EDU will be more suited to an enterprise deployment that can scale to dozens or hundreds of APs, requiring proper, standards-based POE switches for practical reasons.
I purchased an AC LR about a week ago.  It's been a huge improvement over my old setup.  I had an  Asus RT-68U (whatever the model is) AC router and a couple of TP-Link APs (connected via ethernet).  It all  worked, but often times my connections were very slow and unstable.  I've  got a 110 Mpbs  internet connection - so that wasn't the  problem.
With just the  one  AC LR AP, things improved a lot.  I can't say the speed is really any better, but the connection is much more solid.  All my traffic over WiFi seems so much snappier.
I plan to add a second AP in the next few weeks.  The single one provides pretty good coverage in a  2800 sq. ft home.  The second will just make things that much better.
I haven't had any issues running the controller software.  I'd say go for it.
It's been about a week now since I started using it. And boy, was this a good buy! I like to be able to see all wireless clients in a 'single pane of glass'. Block them or adjust their bandwidth if they're being greedy (Android picture backup is notorious). Of course, I will have to change all the remaining APs to Ubiquiti to have unified control.
The USG router is quite nice as well - its basically an Edgerouter Lite but integrated into the Unifi controller and you can see wired clients.
You will then get all your dashboard lit up green :)
Edited by snapper
