itGeeks Posted February 3, 2016 Share Posted February 3, 2016 (edited) Anyone seen or used this case before? http://www.u-nas.com/xcart/product.php?productid=17617&cat=249&page=1 I am also considering this case but I really like the U-NAS case even though its a bit pricy http://www.amazon.com/dp/B00IAELTAI/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2KYYWDBPFYQOQ&coliid=I3UOB6A6R4TF3V&psc=1 I am thinking of pairing it up with one of these two ASRock Server boards, They are both the same except one uses the Intel Avoton C2550 Quad-Core Processor and the other one uses the Intel Avoton C2750 Octa-Core Processor http://www.amazon.com/dp/B00GG94YDS/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2KYYWDBPFYQOQ&coliid=I11FIROXM9LYHK http://www.newegg.com/Product/Product.aspx?Item=N82E16813157475 Thoughts? Edited February 3, 2016 by itGeeks Link to comment Share on other sites More sharing options...
Drashna Jaelre Posted February 4, 2016 Share Posted February 4, 2016 That's about the right price for something like that. Also, have you looked at the Norco ITX-S8 chassis? Link to comment Share on other sites More sharing options...
schoondoggy Posted February 4, 2016 Share Posted February 4, 2016 They did that build here: http://www.anandtech.com/show/9508/asrock-rack-c2750d4i-and-unas-nsc800-a-diy-file-server Link to comment Share on other sites More sharing options...
Drashna Jaelre Posted February 4, 2016 Share Posted February 4, 2016 Yup, saw that myself. Would be nice if the case supported more than 2x SSDs. Link to comment Share on other sites More sharing options...
itGeeks Posted February 4, 2016 Author Share Posted February 4, 2016 Yup, saw that myself. Would be nice if the case supported more than 2x SSDs. The U-NAS has 3 internal 2.5 drive bays for SSD's, I am not sure y U-NAS list it the way they do. According to there spec page they say "2 x 2.5” HDD/SSD + 1x2.5" HDD/SSD" AnandTech also says the case has support for three internal drives. Link to comment Share on other sites More sharing options...
itGeeks Posted February 4, 2016 Author Share Posted February 4, 2016 They did that build here: http://www.anandtech.com/show/9508/asrock-rack-c2750d4i-and-unas-nsc800-a-diy-file-server Thanks for the link, I had not seen that one but I have seen others. I am really itching for this case. My goal is to build a Synology NAS without paying the high cost of purchasing there low powered hardware, I am not talking WATTS but performance at a cost savings of 4-5 hundred dollars for base hardware. I am still undecided if I want to put XPEnology in a VM or bear-metal that will be the deciding factor if I do Octa-Core or Quad-Core. All said and done I want this box to be able to handle Synology as well as real-time trans-coding for Plex without having to run a Intel Core i5 24 hours a day for the Plex Server. On paper it looks like the Octa-Core should be able to handle 3-4 streams with trans-coding and the Quad-Core 1-2 streams, I can only hope this works out. That's about the right price for something like that. Also, have you looked at the Norco ITX-S8 chassis? I guess your right about the price, That's just me trying to keep the cost down as much as possible. I did not see the S8 but I had seen the S4, Thanks for that I have put it on my case list. Link to comment Share on other sites More sharing options...
Drashna Jaelre Posted February 4, 2016 Share Posted February 4, 2016 The U-NAS has 3 internal 2.5 drive bays for SSD's, I am not sure y U-NAS list it the way they do. According to there spec page they say "2 x 2.5” HDD/SSD + 1x2.5" HDD/SSD" AnandTech also says the case has support for three internal drives. I wish they had better product pictures.... I see the spot for 2x 2.5", but not a third. I could be blind, but .... Though, what would be really nice is a LCD panel on the front. Would be the icing on the cake. Thanks for the link, I had not seen that one but I have seen others. I am really itching for this case. My goal is to build a Synology NAS without paying the high cost of purchasing there low powered hardware, I am not talking WATTS but performance at a cost savings of 4-5 hundred dollars for base hardware. I am still undecided if I want to put XPEnology in a VM or bear-metal that will be the deciding factor if I do Octa-Core or Quad-Core. All said and done I want this box to be able to handle Synology as well as real-time trans-coding for Plex without having to run a Intel Core i5 24 hours a day for the Plex Server. On paper it looks like the Octa-Core should be able to handle 3-4 streams with trans-coding and the Quad-Core 1-2 streams, I can only hope this works out. I guess your right about the price, That's just me trying to keep the cost down as much as possible. I did not see the S8 but I had seen the S4, Thanks for that I have put it on my case list. Have you considered something like the ASRock RACK E3C226D2I? http://www.asrockrack.com/general/productdetail.asp?Model=E3C226D2I#Specifications It's a LGA 1150 socket board, with support for ECC. It only has 6 SATA ports, so you'd need to get a controller card... but you can get anything from a Celeron to a Xeon E3 in the system. Or the E3C236D2I? http://www.asrockrack.com/general/productdetail.asp?Model=E3C236D2I#Specifications Similar, but newer CPU support (Skylake S) I don't mean to push, but the reasons I recommend these boards is that you can run low powered systems, or you can run higher end systems. But you can change between them without being locked into a specific CPU. Link to comment Share on other sites More sharing options...
itGeeks Posted February 4, 2016 Author Share Posted February 4, 2016 (edited) I wish they had better product pictures.... I see the spot for 2x 2.5", but not a third. I could be blind, but .... Though, what would be really nice is a LCD panel on the front. Would be the icing on the cake. Have you considered something like the ASRock RACK E3C226D2I? http://www.asrockrack.com/general/productdetail.asp?Model=E3C226D2I#Specifications It's a LGA 1150 socket board, with support for ECC. It only has 6 SATA ports, so you'd need to get a controller card... but you can get anything from a Celeron to a Xeon E3 in the system. Or the E3C236D2I? http://www.asrockrack.com/general/productdetail.asp?Model=E3C236D2I#Specifications Similar, but newer CPU support (Skylake S) I don't mean to push, but the reasons I recommend these boards is that you can run low powered systems, or you can run higher end systems. But you can change between them without being locked into a specific CPU. The E3C236D2I looks like a nice board also, It just stinks it only has 6 SATA ports and it seems like no one has it in stock now. The board also looks like Intel Xeon E3-1200 v5 Series Processors only, Are you sure I can run something other on this board? What controller would you recommend for the extra SATA ports I would need 10 in total? Another thing i really have to decide if I wan't to run EXPenology in a VM using Hyper-V what I am unsure of is can I pass all the storage threw Hyper-V without creating a RAID first on the VM Host? I would want to create the pool threw Synology not use a RAID card on the VM host. If I cant pass the RAW storage threw to the VM and create the pool on the VM running Synology then I would have to scrap the VM idia and run Synology bear-metal. Edited February 4, 2016 by itGeeks Link to comment Share on other sites More sharing options...
Drashna Jaelre Posted February 4, 2016 Share Posted February 4, 2016 The E3C236D2I looks like a nice board also, It just stinks it only has 6 SATA ports and it seems like no one has it in stock now. What controller would you recommend for the extra SATA ports I would need 10 in total? Another thing i really have to decide if I wan't to run EXPenology in a VM using Hyper-V what I am unsure of is can I pass all the storage threw Hyper-V without creating a RAID first on the VM Host? I would want to create the pool threw Synology not use a RAID card on the VM host. If I cant pass the RAW storage threw to the VM and create the pool on the VM running Synology then I would have to scrap the VM idia and run Synology bear-metal. Yeah, the 6 port thing is the downside. However, Amazon does appear to have it in stock: http://www.amazon.com/ASRock-Rack-E3C236D2I-Motherboard/dp/B01B9624AM/ref=sr_1_1?ie=UTF8&qid=1454624647&sr=8-1&keywords=E3C236D2I Also, you could use a controller card (such as an LSI card) to power the drives. You could use the onboard to power 4 slots, and use a 4e 4i card to power the rest and add some expandability. It's a bit pricier that way, but it works. Link to comment Share on other sites More sharing options...
itGeeks Posted February 4, 2016 Author Share Posted February 4, 2016 Yeah, the 6 port thing is the downside. However, Amazon does appear to have it in stock: http://www.amazon.com/ASRock-Rack-E3C236D2I-Motherboard/dp/B01B9624AM/ref=sr_1_1?ie=UTF8&qid=1454624647&sr=8-1&keywords=E3C236D2I Also, you could use a controller card (such as an LSI card) to power the drives. You could use the onboard to power 4 slots, and use a 4e 4i card to power the rest and add some expandability. It's a bit pricier that way, but it works. Thanks for the link and info, When I click the Amazon link it shows out of stock here. I am in the very early stages of planing with this system so I have to see what I want to do, Future proofing is always a good thing to. Do you know the answer to my VM question above? Link to comment Share on other sites More sharing options...
