Cisco SG300-10SFP + Multi-port NICs issue
artiom
Hello to everyone,
I got a strange problem with a switch in the following environment:
Switch: Cisco SG300-10SFP
Servers:
1. Dell PowerEdge T710 with 4-port Broadcom NIC (+1 iDRAC Enterprise port on a separate NIC).
2. HP Microserver G8 with a 2-port NIC (+1 dedicated iLO port).
Problem:
The switch restarts by itself when I connect more than one port of the same NIC, the more ports I connect - the more often it restarts.
For example, if I connect both ports of HP MS G8 - it restarts approx once in two hours, but if I connect all ports of both servers - it restarts continuously and it is pretty unusable.
If I connect all dedicated management ports of both servers and just one nic port of each server - it is rock stable and works perfectly.
The Cisco log does not contain any relevant information. The switch is updated with the latest firmware atm, QoS is disabled and no other specific configurations were made.
I just need it to work as a dumb switch with all ports connected.
Does anyone have any ideas where to dig to fix this problem? Maybe someone already encountered such behavior on Cisco SG300 series?
Thank you for reading!
Hm... the smartport functionality looks disabled, but the "discovery" is enabled - will try to disable and reconnect all cabling this evening. Thank you for suggestion.
Check if port security is off.. that used to cause me no end of problems on the bigger switches I used to manage - kept shutting down the ports on me..
I just tried all sugestions, then I did a factory reset, then reconfigured it back, tried to disable all uneeded services again, etc. And nothing helps :(
Looks like I need another switch... does anyone have a spare 10+ port switch in Bristol, UK? :)
Yeah. It sounds like it is faulty unfortunately. Can you get it replaced under warranty? Cisco offer a limited lifetime hardware warranty on that switch.
Unfortunately, I do not think I can replace it under warranty - I friend of mine just gave it to me as is ~a year ago. It works perfectly unless I connect two or more ports of the same NIC.
I ordered another switch (HP ProCurve 2510G-24) and will test with that one - if it will have the same glitches - then it's something to do with Windows Server 2012 default network configuration.
Thank you for suggestions anyway - the community here is always helpful.
  • 1 month later...
Cisco SG300 switches generally have a lifetime warranty.
I have my HP Microserver Gen8 connected to my SG300-10MPP on two ports in a LAGG with LACP on, and have never had an issue.  I think you have a faulty switch, or you need to upgrade the Broadcom NIC firmware.  I would normally test with an Intel dual-port NIC at this point; I have had quirky issues with Broadcom NICs in some situations that I don't have with Intel.
What operating systems are you using on the systems, and how do you have the link aggregation set up?  Note, I'm not using Broadcom's software; Server 2012 and 2012 R2 have eliminated my need to do so, and I prefer to avoid Broadcom's BACS when possible.  I actually had it break a Windows 2008R2 network stack once; the issues have been bigger for me on Dell servers than others, and I actually had them on the T710.  There are a number of documented complaints about Broadcom on multiple generations of Dell servers up through the x10.
One recommendation: In addition to making sure you have the latest Broadcom firmware and drivers for your NICs, disable TCP Chimney offload if you have issues.  There are plenty of times Broadcom server NICs have an issue with this enabled.
Thank you for suggestions, but currently I can't test them because I replaced the Cisco switch with the one mentioned in previous post (HP 2510G-24) - it is more than enough for my needs and all works perfectly.
