Popular Post raminger Posted January 21, 2016 Popular Post Share Posted January 21, 2016 Recently I added a P420 to my GEN8. But this also increased the case fan speed, even when it was idle. The P420 looks like it has been designed to add a fan on top of the heatsink. With a cheap fan on the heatsink I was able to reduce the temperature to 60°C while under load. For anyone interested, the .stl can be found here: http://www.thingiverse.com/thing:1284618 And some pics can be found here: http://imgur.com/a/MPAEL PS: Thanks to everyone providing your knowledge in this forum, you saved me a lot of time figuring out some stuff with my GEN8! 2 1 Link to comment Share on other sites More sharing options...
schoondoggy Posted January 22, 2016 Share Posted January 22, 2016 Great idea! Nice design. Link to comment Share on other sites More sharing options...
Gurv4n Posted January 22, 2016 Share Posted January 22, 2016 Recently I added a P420 to my GEN8. But this also increased the case fan speed, even when it was idle. The P420 looks like it has been designed to add a fan on top of the heatsink. With a cheap fan on the heatsink I was able to reduce the temperature to 60°C while under load. For anyone interested, the .stl can be found here: http://www.thingiverse.com/thing:1284618 And some pics can be found here: http://imgur.com/a/MPAEL PS: Thanks to everyone providing your knowledge in this forum, you saved me a lot of time figuring out some stuff with my GEN8! Hello, Are you able to post the case fan speed before and after the addition of this fan on the P420 card? Thanks. Link to comment Share on other sites More sharing options...
zxdavb Posted January 22, 2016 Share Posted January 22, 2016 Recently I added a P420 to my GEN8. Hi chap. I wanted to know: does the P420 show up in the ILO like the P222 does? Thanks in advance. Link to comment Share on other sites More sharing options...
Gurv4n Posted January 22, 2016 Share Posted January 22, 2016 Hi chap. I wanted to know: does the P420 show up in the ILO like the P222 does? Thanks in advance. P421 is so P420 should. Link to comment Share on other sites More sharing options...
zxdavb Posted January 22, 2016 Share Posted January 22, 2016 P421 is so P420 should. Thanks for that. I bought a P222, expecting to run 6-8 disks inside the case, but the P222 has 1x internal (SFF-8087) and 1x external (SFF-8088) connector. It seems I should have bought a P420 instead as it has 2x internal connectors (I understand the P421 has two external). Does anyone know of any other differences between them, before I start shopping for a P420? The QuickSpecs says the P4xx are 'Enterprise Class', whilst the P222 is 'Entry-Level' (whatever that means). QuickSpecs: - P420: http://www8.hp.com/h20195/v2/getpdf.aspx/c04111534.pdf - P421: http://www8.hp.com/h20195/v2/getpdf.aspx/c04111167.pdf - P222: http://www8.hp.com/h20195/v2/getpdf.aspx/c04111474.pdf Link to comment Share on other sites More sharing options...
schoondoggy Posted January 22, 2016 Share Posted January 22, 2016 Thanks for that. I bought a P222, expecting to run 6-8 disks inside the case, but the P222 has 1x internal (SFF-8087) and 1x external (SFF-8088) connector. It seems I should have bought a P420 instead as it has 2x internal connectors (I understand the P421 has two external). Does anyone know of any other differences between them, before I start shopping for a P420? The QuickSpecs says the P4xx are 'Enterprise Class', whilst the P222 is 'Entry-Level' (whatever that means). QuickSpecs: - P420: http://www8.hp.com/h20195/v2/getpdf.aspx/c04111534.pdf - P421: http://www8.hp.com/h20195/v2/getpdf.aspx/c04111167.pdf - P222: http://www8.hp.com/h20195/v2/getpdf.aspx/c04111474.pdf From this page you can select each and compare. Will you be using the RAID functions of the controller or are you just looking for 8 internal ports? Link to comment Share on other sites More sharing options...
raminger Posted January 22, 2016 Author Share Posted January 22, 2016 Hello, Are you able to post the case fan speed before and after the addition of this fan on the P420 card? Thanks. Without fan on the P420 the case fan was running at 60-70%, now it's stable on 11%. Hi chap. I wanted to know: does the P420 show up in the ILO like the P222 does? Thanks in advance. Working as expected, it shows up in all relevant tabs in iLO and I also get all infos from my WD Reds. Link to comment Share on other sites More sharing options...
zxdavb Posted January 22, 2016 Share Posted January 22, 2016 The plan is: RAID1 for 2x SSDs (on a SDM) RAID5 for 4x magnetics Link to comment Share on other sites More sharing options...
Gurv4n Posted January 22, 2016 Share Posted January 22, 2016 Without fan on the P420 the case fan was running at 60-70%, now it's stable on 11%. Working as expected, it shows up in all relevant tabs in iLO and I also get all infos from my WD Reds. That's very weird. Which cooling mode are you using? With P421 running under ESXi 6, I'm around 16% Link to comment Share on other sites More sharing options...
