Help! HP Proliant Microserver G8 g1610T (Drivers 332i)
macallan
Hello
I need driver HP Ethernet 1Gb 2-Port 332i Adapter.
In the website of HP support, are only the following model :(
https://h20565.www2.hpe.com/portal/site/hpsc/template.PAGE/public/psi/selector/?javax.portlet.tpst=867000c4cf25636cc859bfdeb053ce01&javax.portlet.prp_867000c4cf25636cc859bfdeb053ce01=wsrp-navigationalState%3D_queryText%25253D332i%252BaDAPTER%25257CimplicitModel%25253Dtrue%25257C_op%25253Dfind&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
HP Ethernet 1Gb 2-port Adapter 330i
HP Ethernet 1Gb 2-port 332T Adapter
HP Ethernet 1Gb 2-port Adapter 361i
HP Ethernet 1Gb 2-port Adapter 331i
HP Ethernet 1Gb 2-port Adapter 366i
If it's drivers you want for the NIC's on the Gen8 you can get them at:
HP ProLiant MicroServer Gen8 Drivers and Software http://h20566.www2.hpe.com/hpsc/swd/public/readIndex?sp4ts.oid=7298965〈=en&cc=us
Just select what OS you are going to use -- for Win8/8.1 or Win10 go with S2012R2 (for Win7 go with S2008R2)
HP ProLiant MicroServer Gen8 Drivers and Software for MicroSoft Windows Server 2012R2 Downloads http://h20566.www2.hpe.com/hpsc/swd/public/readIndex?sp4ts.oid=7298965&swLangOid=8&swEnvOid=4168
Edited by Joe_Miner
