dvn Posted December 12, 2009 Share Posted December 12, 2009 I'm having trouble setting up the Remote Notification add-in. For cell, I used my 10-digit number and txt.att.net. Didn't work. For email, I tried my username @ gmail.com, smtp.gmail.com, on port 25 - no-go on that.I tried my username @ gmail.com, smtp.gmail.com on port 465 using SSL - no-go on that either. I also tried the Authentication option along with SSL, supplying my username and password, and that didn't work. What am I missing? Link to comment Share on other sites More sharing options...
dvn Posted December 12, 2009 Author Share Posted December 12, 2009 I also tried 'cell number @ mms.att.net' - no-go on that Help, anyone? Link to comment Share on other sites More sharing options...
Vulcan Posted December 12, 2009 Share Posted December 12, 2009 Google has a few settings to configure if you want to pop G Mail....You also have to have a supported mail client installed.G Mail Pop Settings Link to comment Share on other sites More sharing options...
dvn Posted December 13, 2009 Author Share Posted December 13, 2009 Vulcan, thanks for the input. I had set everything correctly according to that link you posted. So, I finally did get it working. Know how? I applied the settings, closed out the WHS console, THEN restarted the console and went to the Remote Notification tab. This time, when I sent myself a test notification, it worked. *On a humorous note, I enabled 'Suppressed Notifications' under General Settings, and got spammed with about 6 messages right after another by my own server with warnings about anti-virus and PC backup status. Hilarious! Link to comment Share on other sites More sharing options...
Vulcan Posted December 14, 2009 Share Posted December 14, 2009 Glad its working for you now....The magic of a restart (best computer fix -it tip ever!!) Link to comment Share on other sites More sharing options...
