Rack mounted in home environment
artiom
With the server you have in mind, that is a real server from a hardware standpoint.  Most anything you can build will most likely be from desktop components, except for CPU and RAM.  I oculd do alsmot the same thing with a tower, but I would need a new MOBO that would hold the RAM needed so the cost of buying used was the overall deciding factor.
Now for about $1500 US I can get down to a small form factor such as the SuperMicroServer that would hold 128 gigs RAM in a foot print of a Gen8
What are the advantages of a tower case except noise? I have the impression that a rack mount will allow for a much denser packing as together with one or two servers you can mount everything else as well - like network equipment, UPS, etc.
Tower servers will have a much smaller physical footprint. Rackmounted servers are the standard 19" wide but they'll be somewhere close to 30-40" in depth. They usually have more expansion slots. They're not as loud. They don't require a rack enclosure. They're the equivalent hardware of a rackmounted server but inside a tower case. They're not regular desktop PCs.
You say that you're looking for much denser packing of servers + other equipment but you're also looking for a fairly large rack enclosure and you're only going to put a maximum of 4 servers into it? Your requirements are conflicting there.
Edited by GotNoTime
Not quite. 4 Rack servers will take less surface than 4 towers of similar capabilities.
While a tower is great as a single server - the more server you add - the better racks become. Then count at least a switch, a PDU, UPS, cable management, etc - and a rack cabinet becomes much more compact.
Anyway, we drifted from the main topic :)
Can you give a few examples, please? This sounds interesting... because if I count everything like harware/racks/energy/etc - I get close to such sums... so maybe just build something custom?
I have a 24U open-frame rack in a spare room in my basement (it's basically a small storage room).  Currently it has a 2U and 3U server running and while I can sort of hear the fans upstairs when they reboot - they spike to full speed for a second or two - it's otherwise unheard.  The servers have Supermicro cases and boards that I bought separately, one runs an i3 while the other is a Xeon E3.  There's also a shelf for a monitor and KVM, a network switch, an inactive 2U box and a 2U UPS in the rack.  I had a 1U Atom server in there running pfSense, but it's since been moved to a small wall-mounted rack in an effort to clean up some of the cable routing between the wall panel and server rack.  Even if I'm in the basement, as long as the door to that room is closed it's pretty quiet.
Location-wise, I'm around the 42nd parallel, yesterday was around 0F and today is around 25F.  We get up to 80-90F and sometimes higher in the summer along with 90% humidity.  I agree, the attic is a bad place, too much dust and whatever else with the insulation up there.  I've been doing some renovation/repair work in my basement and while I do notice that I should wipe dust off the servers periodically, they don't seem to mind too much.  I do have a pair of dehumidifiers down there in different ends of the main area that fill up quite fast in the summer but that hasn't caused too much trouble either.  I did learn not to put a dehumidifier on the same circuit as the UPS - it went into battery mode every time the dehumidifier started back up.
Wow, that Xeon D-1540 is really tasty :)
While the performance is somewhat lower than of two L5640, it is much smaller. Really nice device...
Paul has done a nice job with that unit.  If you have a case, then you could price the board, RAM, and CPU separately to see how much of a cost savings there is.  IIRC, his power consumption was around 65 Watts.
Well, looks like it has unmatched performance per watt - but the components aren't available separately in UK and the price from the link above is ~1200GBP
@Andne, thank you for information - nice to hear a confirmation that it is fine to have an open-frame rack :)
What are the experiences using a custom-built rack server over branded ones? Is it worth to pay for the brand in a home lab?
    • csadam
      By csadam
      Does anybody know exactly where is the 11-PCI 1 Zone  temp sensor on the motherboard?
    • okepi_malin
      By okepi_malin
      Hi everybody.
      I have a Gen8 G1610T since 2 years and I am very happy with it. I use it to only host my Plex Server with 3*2Tb drives.
      I bought for a cheap price (40€) a Xeon E3-1220v2 and I have question about it. I have read Elvisdk's topic about temperature with G1610T default heatsink on 1220v2 and I wonder if play (and transcode) 1080p movies with 4 cores enable will be ok or too hot ? Did I must enable only 2 cores to be safe ?
      I cannot compare Elvisdk's temperature with wPrime burnt with the temperatures generated by Plex because I don't know them with a E3-1220v2...
      Thanks for your feedback.
    • ICYDOCK_Chris
      By ICYDOCK_Chris
      ICY DOCK is the leading expert in data storage enclosures and accessories.
      Introducing ToughArmor
      ToughArmor is ICY DOCK’s rugged enterprise-grade line of 2.5” SSD and HDD enclosures, utilizing the standard external 5.25” bay, external 3.5” bay (floppy bay), and the slim optical bay (ODD bay). All ToughArmor models feature ruggedized full-metal enclosures and trays, to keep your sensitive data protected, as well as meeting many flammability requirements. It features many high-density storage options, supporting as many as 16x 2.5” drives, or as few as one. Models are available to support SATA, SAS, and now, U.2 NVMe drives, giving you flexibility in choosing drives that work best for you. The strength and build quality of all of our products is backed by a full 3-year warranty against all defects. ToughArmor is used and approved by Tier 1 companies such as Hewlett Packard (HP), General Electric, NASA, as well as the US Armed Forces. For more information on our ToughArmor line, read our ToughArmor documentation here. Links to all of the products discussed here can be found in the documentation. All ToughArmor products can be view here.
      ToughArmor for SATA 3.5” / 5.25” Bays
      For SATA and SAS drives installing into 3.5” and 5.25” bays, we have a large number of options available. In the 3.5” bay, there are models that support one to three drives, some with features such as key-lock trays and hardware RAID capabilities. The larger 5.25” bay supports between four and eight drives in a single bay, and up to 16 when using two bays. These denser options offer cooling fans, to keep the large number of drives cool under heavy load. These models have a wide array of uses. The MB991U3-1SB is our portable ToughArmor unit you can take anywhere, and works over USB. The MB992SKR-B is a 2-bay model with a hardware RAID chip, with modes for RAID 0, RAID 1, BIG, and JBOD.
      There are also our more traditional drive carriers that install into a single 5.25” bay. While these models don’t have USB support or a RAID chip, they still have direct SATA connections, the full-metal enclosure, and the 3-year warranty.  The 4-bay (MB994SP-4S), 6-bay (MB996SP-6SB), and 8-bay (MB998SP-B) models are perfect for any general applications that require hot-swappable SATA hard drives and SSDs in a dense storage enclosure.
      ToughArmor for NVME
      Recently, ICY DOCK has released the first-ever hot-swap cages for U.2 NVMe drives.  U.2 drives use the standard 2.5” size familiar from SATA SSDs, but utilize the NVMe specification allowing for transfer rates of up to 32GB/s. ICY DOCK U.2 NVMe cages come in one and four bay models, and utilize a single Mini-SAS HD connection for each drive. The single-bay model (MB601VK-B) fits in a single 3.5” bay, great for space-limited tasks that require only a single drive.  Small-form-factor systems, DVR systems, and photo/video editing systems can benefit from high-performance storage in a small space. If you need more drives, the 4-bay model (MB699VP-B) is the one for you, and even works great in RAID setups.  These are used in datacenters around the world, that need dense NVMe based storage. Both of these models use a Mini-SAS HD port / cable for each drive, so make sure to prepare your system with enough Mini-SAS HD ports.
      ToughArmor for Optical Drive Bays
      ICY DOCK also has several drive cages that fit into slim (12.7mm) and ultra-slim (9.5mm) optical drive bays. These can serve to replace existing drive readers in laptops and desktop systems, and can also be paired with several of our 5.25” bay brackets. Perfect for space-critical applications that require drives to be installed in the smallest possible space. Common uses are in Small-Form-Factor PCs, media PCs, Home Theater PCs (HTPC), and security footage systems. In industrial uses, these are often found in 1U and 2U rack-mounted systems with limited space availability, and portable workstations/laptops.
      If you have any questions about the models mentioned here, or anything else, send us an email at tech@icydock.com. We offer first-class customer support for all our products, from pre-purchasing info, product selection help, walking you through installation, and issue troubleshooting. In addition to email, we offer phone and live web-chat customer support, which can be found here.  Our knowledgeable support technicians are available Monday-Friday from 10:00am-5:00pm PST.
    • Dave
      By Dave
      I've been a big fan of this product and have it running in my home.  It's now $20 off if you follow this link.
      http://mbsy.co/circlemedia/mccabeio
      There is an Amazon link to buy it and December 17th to 22nd it will also be $20 off on the Circle website.  So heads up!
      Take a look at the video below for a better understanding of what it can do for you.  In my house, if anything hops on my wifi the box will notify me immediately.  I've set it up so anything that jumps on is put in a KID friendly profile.  I look at what they are seeing on their iPads and can turn off apps. YouTube, Safari, App Store = Off.
    • TSa
      By TSa
      Hello!
      I made stupid mistake and bought gen10 microserver because it looked nice.
      Hardware is like this:
      Samsung 850 pro 256 for OS win10 pro
      2x wd red 4tb in SW raid
      1x wd green 3b
      It is loud as hell when booting and very irritating after that.
      There is just too much noise from fan for quiet home office.
      Is there anything i can do about it?
      Please help my ears bleed!
      -TSa
