Network Setup – Router LAN – DHCP Settings
doliveira
I think that settings up this way, when my server in turned ON all my office computers will use the server as DNS and when the server is turned OFF all the my office computers will use the router as DNS.
You don't want to have your primary DNS server to occasionally vanish because the server is off since devices will still attempt to query it which will mean delays. Just set the router as primary and nothing as secondary.
I have the TL-ER5120 and Server 2012E- R2.
I have DNS on router just in case server is off or rebooting.
Default Gateway set to router, 192.168.0.1 in my case and probably yours too. ( I bet is will work fine if this box = empty)
Default Domain = empty
For Primary and Secondary DNS I use my ISP DNS because it is the fastest.  I tested it using Steve Gibsons "DNS Benchmark" a free tool that tells you the fastesr DNS from your place.
https://www.grc.com/dns/benchmark.htm
I am NOT using AD. No domain.
Leave DNS on the router.
Hi GotNoTime and jmwills,
Ok, so i will make DNS to run only on the router.
Hi Poppapete,
Glad to finnaly see someone else on this forum using the TL-ER5120!
The only difference i see from my setup to your setup is that i'm using a a domain private network (mydomain.local), correct?
So from what i have understand from your post i should change from my current settings:
Default Gateway: 192.168.0.1  (this is my router IP)
Default Domain: myoffice.local (this is my windows network domain name)
Primary DNS: 192.168.0.10 (this is my server IP)
Secondary DNS: 192.168.0.1 (this is my router IP)
to this new settings:
Default Domain: leave blank
Primary DNS: 192.168.0.1 (this is my router IP)
Secondary DNS: leave blank
Can you please tell me if i understand properly and tell me what are the best settings?
If the client computers are joined to the domain, then the server needs to provide the DNS for them.  There may be a way to have the router forward myoffice.local queries to the server, but given all of the different record types and whatnot that exist for active directory I'm not sure if that'd be reliable or not.
At one point there was a service that came as part of the connector that watched for the server being on the network but not being provided at the DNS and would automatically change the client computers to use it instead of the ones provided by the router.  I don't know if that service is still there or not.  Also, I remember it sometimes fouling up my computers such that when I wasn't on the network they wouldn't reset to using the DHCP-provided DNS servers.
Hi Poppapete,
Not so fast.
First is I am not using AD, not on a domain. I have no experience with AD but I am pretty sure the server needs to supply DNS for clients as Andne explained. My settings are for clients connected using the "SkipDomainJoin" and then using the regedit "SkipAutoDNSServerDetection" set to True.  If your clients are Domain Joined then my setting are not good for you. My guess your settings for this page should be:
Default Domain: I would leave empty and suggest this is used if you have more than one domain
Primary DNS: Server IP Address if you are using AD
Secondary DNS: I would leave empty
but take advice from someone who has not skipped the domain join.
If you have time read this, it is a little out of date but great explaining DNS and Windows Server
http://windowsserveressentials.com/2013/06/17/unravelling-the-mystery-of-client-dns-with-essentials-family-servers/
    • JROrtiz
      By JROrtiz
    • Jason
      By Jason
      Have been running a Windows DHCP server on home WSE12R2 box for quite some time behind my Sophos UTM firewall. Also allowed me to seamlessly run Windows Deployment Services at home. WDS just worked.
      But if I needed to make a particular LAN IP address exception on the firewall, I had to 1.) create a Windows DHCP server reservations AND 2.) create a network definition for that IP on the Sophos UTM box. 2 steps. Not very efficient; was sure I was doing something incorrectly...
      Tried to migrate to Sophos UTM running the DHCP Server, but now WDS doesn't work. LAN devices can no longer PXE boot. Seems possible. Many guides. None have proven especially successful.
      Is it possible to run a Windows DHCP server and have Sophos UTM import DHCP reservations instead of maintaining 2 unique entries for each IP reservation (one in Windows DHCP, another on Sophos UTM box)?
      What is best practice?
    • donschmidt
      By donschmidt
      Good morning.  I've just  purchased a home still under construction and plan to have CAT6 installed throughout the living areas. I'm hoping that someone can advise me as to the specific quality/specs of cable that I should use.
      Thanks and Happy New Year.
    • Joe_Miner
      By Joe_Miner
      I've been looking at the Intel Compute Stick BOXSTK1AW32SC and was wondering if anyone here has experience with that and if the Intel AC 7265 built into it is backwardly compatible with older N and A,B wifi?
    • heavy21
      By heavy21
      I want to optimize the performance and security of my home network of servers, PCs, laptops printers, smartphones, TVs, etc.  Current network appliances include layer 2 and 3 switches (Cisco small business) and Linksys router.  I’m looking to replace the Linksys with a security (pfSense) router appliance (w/OpenVPN).  I will also be adding security cameras and a NVR to the network.
      The gigabit network is straightforward in structure with all Ethernet connections hanging off the24 port switch connected to the cable modem and router except a cascaded 8 port switch in a room to provide 4 Ethernet connections in a room with only one data port.  Wireless connections presently come off the Linksys but will eventually come off the to-be-purchased security/router appliance with a wireless card.  I don’t see more than 100 devices in total for the whole network.  No VLANS and no sub-netting.  All hardware supports IPv6.
      Hardware line up is:
      Dual Zeon server w/RAID 10 of 24 TB of storage, 64GB memory
      Cisco managed switches layer 2 and 3
      HPEX495 server
      Workstations, Desktops, Laptops, Tablets, iPads
      Printers
      Software line up is:
      Windows Server Essentials 2012 R2, single domain controller, storage and file server duties
      Windows 10 Pro all non-server Intel computing devices
      PLEX server for streaming audio and video to display units
      Office 365
      From what I’ve read so far, it appears that I need to incorporate an IP addressing scheme for clients and servers on the network.  It would also appear that I need to implement VLANS and/or sub-netting to protect access to certain files and security footage, provide guest networking with future consideration for electronic door locks and some sort of server based media distribution to various display devices,
      What are best practices on assigning client and server devices to IP ranges, fixed or dynamic IP addresses?  Do I need to assign clients or servers to IP ranges?  What are the considerations in establishing sub-nets over VLANS or vice versa?  I’m pretty sure I want to restrict access to cameras and their security footage and personal files on my workstation.
      Thanks for any resources and advice provided.
