HP MSgen 8, help for BIOS settings
erik
Hi, first posing, but long time reader.
Thanks for all the good information I got here.
Actually I am having a problem with configuration of the Bios (HP gen8 MiroServer, #819185-421, Bios: J06, 06/06/2014).
iLO 2.10, but I am not using iLO advanced server licence
Seems its loosing data without power. After one day of no power plugged in, all settings are back to default. Time/date setting, Auto-Power-On-Status, Boot-Order, a.s.o. Some hours without energy seems to be ok, overnight switch off resets.
Also iLO Event Log contains only data from last switch on.
I have checked the Bios-battery (CR2032) ok. with 3V.
As the Bios is loosing its time setting and even more and the battery is good, I assume some fault on the motherboard and would change the server under warranty.
But first I'd like to ask some of the experts, if there is anything I can do (or configure).
Or confirmation that a server change is the way to go.
Any support is highly appreciated.
Erik
