need help with whs2011 / router ip address problem...
capall
Hi all,
I have a whs 2011 setup on a HP micro server  and following the suggestion of the whs book I setup the server with a static IP address from within whs2011 software in the network settings. I then setup a sonos and had no problems pointing sonos to my music stored on my 'music' shared folder. I then changed router from a dir655 to a ASUS AC56U and my sonos was no long able to access my shared server drive.
I remembered about the static IP adr, and so re-did that process within the whs2011, but still no luck.
I also saw on the AC56U setting page that there is an option to lock an IP address for a particular client, which I did for the server, I entered the same number i chose within whs2011, and locked it,  bit still no luck
I ran the command 'nslookup servername' and it can't find the server also.
is there some setup step I'm not doing correctly here.?
thnaks
derek
Have you tried accessing server by IP address rather than server name? Maybe just the dns on the home network is messed up.
Edited by revengineer
so this is strange,
if I send this command "nslookup servernmae" (without the quotes), I get the following
server; router.asus.com
address; 192.168.1.1
if I send this command "nslookup" (without the quotes), I get the following
is there some conflict happening between the router and whs2011?
my router address is 192.168.1.1
and server adr is 192.168.1.xxx
and should I have added the servers ip address and locked it, in the routers server client profile?
is this only  for accessing the server from outside my home network?
so my understanding is that sonos mounts the shared drive as an smb share via its ip adr. I was able to mount a pc on my network as a sonos ,ibrary, so that tells me my sonos is fine. Therefore it must be something with the server ip adr / router sharing
the ping returns the servers Link-Local IPv6 Address, listed in its network connection details
yes sonos is looking to use \\servername\share terminoligy
To make sure the Share can be accessed type:
\\192.168.1.xxx\D$ or C$  If you can get to these hidden shares then at least the server is accessible from a client
Then try replacing server name with IP address
\\192.168.1.xxx\share
In the Sonos. Does that work?
no luck with this
no luck
still getting message that the server can't be accessed
