I used to think I was smart... Then I tried to configure VOIP on my Sophos UTM 9
azcoyote
So I have the simplest implementation.
Sophos 9 fully up to date
PPPOE works great
Outbound rule allows all network to do whatever
I have a VOIP provider that terminates SIP for me.
I have a FreePBX server that acts as a phone system.
I could make these work behind every other firewall I have owned.  I am stumped.
In the simplest fo terms, can anyone tell me what rules to create enable etc?
I have Hosts defined for the external server and internal server and internal SIP handset.
I have protocols defined in services
I have even turned on VOIP --> SIP and set the networks as described in documentation.
My PBX says it is registered to the SIP provider.
Inbound calls do not receive audio channel but they ring.
Outbound seems to just do nothing.
I know this cannot be that difficult or complex for a home PBX terminated to a SIP provider.
Anyone out there able to give me some tips, pointers, directions, Ouja commands, elixer recipes, or straight up voodoo spells??
I will take anything at this point....
Thanks!
W
So I solved this.... by using a STUN server on my PBX.  GRC still shows me locked down tight so I guess that is good.
As to the rules?  No idea....
I haven't had voip for a while but it seems to me you would need some port natted through, do you have any details about what ports are used etc?
Try this method see if it helps, I am using an old RT32P2 for VOIP service in my home, I give it a fixed lan ip
In "Network Definition" I created a Host for it (client) and also create a Host for my VOIP service provider (server)
then in the "Network Protection - VOIP" I enable SIP protocol support and put the "server" under "SIP Server Networks"
and put "client" under "SIP Client Networks"
and voila, my VOIP works, according to SOPHOS this will create some hidden firewall rules to enable the SIP protocol 5060
a side note here
I had similar experience at the very beginning, I believe I read somewhere that there are bugs in firmware require you to open some RTP ports (range depends on service provides) in addition to all the configs you've done in order to make it work.
I tried it works,
And I reinstalled the system and setup VOIP as above and then upgrade firmware, this time no RTP ports rules required, VOIP still works, interesting
Edited by CarsonKT
