2012 Essentials connection issues
eddieb76
I'm having problems with the Windows Server Essentials 2012 (NOT R2) connector software.  I've been on a bunch of web sites and still am unable to resolve them.
To Start:  I'm running WSE 2012 (non R2), a real plain install, none of my clients are on a domain (I added the key before installing the connector).  I can ping the server by name from all of the clients.
 All my clients were running fine.  I updated one client to Windows 10, no problem.  The second Windows 10 Pro client has the connector installed, but can't run backup (I do get the notifications).   I can ever remote the server and map drives to it.  Next, I added a completely new computer, and on that one, I download the connector, and get the "Cannot locate or identify your server" error.  Entering the or IP address here does nothing.  The other remaining clients work fine.
At this point, I'm thinking that maybe I did something to the server.  Somewhere in the interim, I installed SubVersion on the server.  I believe that it uses Apache, but even with that shut down, I am unable to install the connector.
From my computerconnector.log file on the client:
[11/26/2015 21:38:17 1798] wmain: Start of Computerconnector
[11/26/2015 21:38:17 1798] wmain: Calling Computerconnector::ShowWizard()
[11/26/2015 21:38:17 1798] CComputerconnector::ShowWizard: Initializing common controls
[11/26/2015 21:38:17 1798] CComputerconnector::ShowWizard: Done initializing common controls
[11/26/2015 21:38:17 1798] Displaying the wizard
[11/26/2015 21:38:17 1798] CComputerconnector::AnotherInstallationErrorDlgProc: IDD_ANOTHER_INSTALLATION_ERR Page Initialization
[11/26/2015 21:38:17 17c0] CComputerconnector::Run: Installation is ready to run
[11/26/2015 21:38:17 17c0] GlobalData::Initialize (192.168.1.14, , C:\Users\EAdmin\Downloads\ComputerConnector(192.168.1.14) (3).exe, 1033)
[11/26/2015 21:38:17 17c0] ExpandEnvironmentStrings return (C:\WINDOWS\Temp\Client Deployment Files\)
[11/26/2015 21:38:17 17c0] CComputerconnector::Run: Running Task: Id=1 Description=Downloads the Setup.cab file
[11/26/2015 21:38:17 17c0] NetworkUtil::DownloadFile (https://192.168.1.14:443/Connect/default.aspx?Get=Setup.cab&64bit=1&LanguageId=1033, C:\Users\EAdmin\AppData\Local\Temp\Setup.cab)
[11/26/2015 21:38:17 17c0] NetworkUtil::DownloadFile - Create directory [C:\Users\EAdmin\AppData\Local\Temp] if not exist.
[11/26/2015 21:38:17 17c0] NetworkUtil::_WinInetDownloadFile (https://192.168.1.14:443/Connect/default.aspx?Get=Setup.cab&64bit=1&LanguageId=1033, C:\Users\EAdmin\AppData\Local\Temp\Setup.cab)
[11/26/2015 21:38:17 1798] CComputerconnector::AnotherInstallationErrorDlgProc: DIALOG_UPDATE: PreCheckPass
[11/26/2015 21:38:17 1798] CComputerconnector::ConnecttingDlgProc: IDD_CONNECTING Page Initialization
[11/26/2015 21:38:17 17c0] InternetOpenUrl (https://192.168.1.14:443/Connect/default.aspx?Get=Setup.cab&64bit=1&LanguageId=1033) returns 12045
[11/26/2015 21:38:17 17c0] _WinInetDownloadFile returns 0x80072f0d.
[11/26/2015 21:38:17 17c0] DownloadFile failed using https. Try http.
[11/26/2015 21:38:17 17c0] NetworkUtil::DownloadFile (http://192.168.1.14:80/Connect/default.aspx?Get=Setup.cab&64bit=1&LanguageId=1033, C:\Users\EAdmin\AppData\Local\Temp\Setup.cab)
[11/26/2015 21:38:17 17c0] NetworkUtil::_WinInetDownloadFile (http://192.168.1.14:80/Connect/default.aspx?Get=Setup.cab&64bit=1&LanguageId=1033, C:\Users\EAdmin\AppData\Local\Temp\Setup.cab)
[11/26/2015 21:38:17 17c0] Download from url: http://192.168.1.14:80/Connect/default.aspx?Get=Setup.cab&64bit=1&LanguageId=1033failed with HTTP error 500
[11/26/2015 21:38:17 17c0] _WinInetDownloadFile returns 0x8000ffff.
[11/26/2015 21:38:17 17c0] NetworkUtil::DownloadFile(http://192.168.1.14:80, Connect/default.aspx?Get=Setup.cab&64bit=1&LanguageId=1033, C:\Users\EAdmin\AppData\Local\Temp\Setup.cab) failed with hr = 0x8000ffff.
[11/26/2015 21:38:17 17c0] CComputerconnector::Run: Task: Id=1 Failed
[11/26/2015 21:38:17 1798] CComputerconnector::ConnecttingDlgProc: DIALOG_UPDATE: ServerNotFound
[11/26/2015 21:38:17 1798] CComputerconnector::ServerDlgProc: IDD_SERVER Page Initialization
[11/26/2015 21:42:20 1798] wmain: End of Computerconnector: hr=0x0
