Removed Battery Wont Boot
ziki
I accidentally removed batter from mobo for 3 seconds, put it back in and now it will not POST. IT does an endless loop where it reboots when it reaches the windows logo loading screen. Entered BIOS set correct date, but that wasnt it.
This is what i have done. BTW i have the modded bios for the port multiplier setting. Maybe it forgot an ahci setting or something that was needed there? It was a long time ago that i had tweaked that and i dont remember anything
That's your problem.  It needs to be set to the first boot device.  There should be a way to select the boot device at startup.
I am not asking why, i am asking how. How did it happen, and how can i change it back. As i posted above on the manual, there is no way to set it to master via jumpers, and i cannot find a way so that the bios sees as master. So again how, do i change it to master
