SOz92 Posted October 30, 2015 Share Posted October 30, 2015 Hi everyone here,I have the Microserver about 1 year ago, but today im interested in do a RAID5 with 4x3TB, at the moment i have the moded BIOS, but when I enter in the ROM Utility to do the RAID, there's no option for the RAID5, I dont know if i need to update something or what I have to do...Someone can help me? Thanks Link to comment Share on other sites More sharing options...
schoondoggy Posted October 30, 2015 Share Posted October 30, 2015 RAID5 is not supported by the motherboard RAID. If you want RAID5 you would need to add a RAID controller. Link to comment Share on other sites More sharing options...
scorpi2ok2 Posted October 30, 2015 Share Posted October 30, 2015 (edited) or if you can create a software raid. Edited October 30, 2015 by scorpi2ok2 Link to comment Share on other sites More sharing options...
genna87 Posted August 16, 2016 Share Posted August 16, 2016 Hi all, I have the exact same problem. Could you link me which RAID controller I should buy, and possibly a tutorial?Any help would be appreciated Link to comment Share on other sites More sharing options...
genna87 Posted August 19, 2016 Share Posted August 19, 2016 Anyone can help me? Link to comment Share on other sites More sharing options...
schoondoggy Posted August 19, 2016 Share Posted August 19, 2016 Hi all, I have the exact same problem. Could you link me which RAID controller I should buy, and possibly a tutorial? Any help would be appreciated What operating system are you using? How many drives do you have? What useable capacity do you need? Have you looked at Drive Pool? Link to comment Share on other sites More sharing options...
genna87 Posted August 20, 2016 Share Posted August 20, 2016 I'm running Ubuntu, but I'd like to do an hardware RAID with 4 3TB Hark Disks Link to comment Share on other sites More sharing options...
schoondoggy Posted August 20, 2016 Share Posted August 20, 2016 HP RAID controllers work well in MicroServers. P212 and P410 with memory will support RAID5, but SATA runs at 3Gb/s. P212 and P420 run SATA 6Gb/s, but they are more expensive. You will need to check on driver support. Link to comment Share on other sites More sharing options...
genna87 Posted August 22, 2016 Share Posted August 22, 2016 In other topics I found some info about the P410 and the P410iCould you confirm me this would be what I'm looking for?http://www.ebay.com/itm/201601322119 Link to comment Share on other sites More sharing options...
schoondoggy Posted August 22, 2016 Share Posted August 22, 2016 In other topics I found some info about the P410 and the P410i Could you confirm me this would be what I'm looking for? http://www.ebay.com/itm/201601322119 That will not work, it is a P410i, It is designed for blade servers. You would need a P410. Link to comment Share on other sites More sharing options...
