A few setup questions
CaptainFred
When I make these changes in ilo it says it needs to be "reset" to take affect.... how do you do that? it's bad terminalogy imo, because really it means "restart" doesn't it.... reset could mean reset to factory defaults!
Did find this... http://www.thevirtualway.it/2014/05/hp-ilo-how-to-reset-from-command-line/
Edited by CaptainFred
Information -> Diagnostics
Factory reset is done via the console utility that prompts you at startup.
The reset button on your PC doesn't reset it to factory defaults *shrug* Edited by GotNoTime
Yes I know I don't want to reset it to factory defaults, it says it needs a reset after I've made some config changes to ilo.
Going back to my above questions....
Please can you let me know how I tell I'm in RAID, AHCI or Legacy mode? See pictures above... it's not clear as they all say "Enable"
I know. I'm telling you that the reset iLO button is on Information -> Diagnostics in the web GUI but if you did you want to factory reset then you can do it via the text setup utility that appears on the console at startup.
It is a multiple choice selection. It isn't 3 different toggles for each mode. Whatever mode you pick is the one enabled. It will show it in the small box in the lower left corner also.
from your screenshot I can tell you that you are in RAID mode.
Thanks. How can you tell? I obviously have that one highlighted...
