GotNoTime Posted October 2, 2015 Share Posted October 2, 2015 Not sure which one you are using, but the .NET one works fine still for me after update to 2.30I was using the standalone .NET one. I would get an error saying the remote end has forcibly closed the connection. I'll test it again tonight. I reset iLO and powercycled the entire box. Link to comment Share on other sites More sharing options...
Shonk Posted October 2, 2015 Share Posted October 2, 2015 Standalone .NET one is still fine for me.. Link to comment Share on other sites More sharing options...
GotNoTime Posted October 2, 2015 Share Posted October 2, 2015 Standalone .NET one is still fine for me..Odd. I wonder what is going on with mine. Link to comment Share on other sites More sharing options...
snapper Posted October 2, 2015 Share Posted October 2, 2015 (edited) We should be able to use non ecc with the new bios.. doesnt work, tried it last night. i3-3220T with ECC memory works fine on new firmware. When I put in a non-ECC memory stick, it doesn't get past the "memory and qpi init" part of POST. I have a i3-3240 here that I might try tonight once everyone has gone home. Edited October 2, 2015 by snapper Link to comment Share on other sites More sharing options...
Shonk Posted October 2, 2015 Share Posted October 2, 2015 (edited) Thats a touch ott if they only allow non ecc on the new cpu's Edited October 2, 2015 by Shonk Link to comment Share on other sites More sharing options...
snapper Posted October 2, 2015 Share Posted October 2, 2015 i'm not convinced those i3's are not ecc capable. ARK used to say they were ECC capable but then it was changed. no-one seems to have found out why. I manage a client machine that has a i3-3220T installed. According to ARK, this is a non-ECC CPU but iLO seems to suggest ECC is working... 1 Link to comment Share on other sites More sharing options...
Snookiwooki Posted October 2, 2015 Share Posted October 2, 2015 I have a Gen8 with an i3 3225 which doesn't officially support ECC but as posted HSS Pro, the server will not boot without ECC. I speculate the BIOS is configured to require it as part of the BIOS Post, though the CPU will not use\address the additional bits present in an ECC module. -Steve Link to comment Share on other sites More sharing options...
snapper Posted October 2, 2015 Share Posted October 2, 2015 I have a i3-3240 here that I might try tonight once everyone has gone home. I have now tried the i3-3240 with 4 makes of non-ECC ram and it doesn't POST. Works right away with ECC ram. I personally think ARK is wrong and these i3's are ECC capable... Link to comment Share on other sites More sharing options...
GotNoTime Posted October 2, 2015 Share Posted October 2, 2015 Standalone .NET one is still fine for me..I just tried iLO 2.30 again and still get the same result. I'll try doing a complete reset to defaults on iLO. Link to comment Share on other sites More sharing options...
GotNoTime Posted October 2, 2015 Share Posted October 2, 2015 (edited) Standalone .NET one is still fine for me..I've worked out what it is. I have the "Enforce AES/3DES Encryption" option enabled in Administration -> Security -> Encryption. Turning it off makes the remote console work again with iLO 2.30. HP did some security + encryption related changes in iLO 2.30 which seems to have broken the standalone + mobile remote console apps when the better encryption option is enabled. iLO4 2.30 release notes. Edited October 2, 2015 by GotNoTime Link to comment Share on other sites More sharing options...
