Andne
NetGear Smart vs. Managed vs. Cisco Small Business vs. ?
itGeeks
The main reason I posted them together is I would like to use same/similar hardware in both locations so that what I learn at home I can apply to the parish network as well.
I would think that the router and switch still need to be aware of the VLAN so that the connections can be routed correctly.  The Open-Mesh hardware may be able to separate out the wireless networks, but how does that isolate the guest wireless from the parish LAN unless the router is also aware.  I suppose the switch could maybe be dumb since it'll just forward the packets along anyways, but I think then I'd basically have every endpoint on the network connected to a trunk port which I assume is not a good thing.  Even if that works and the access point does some filtering, I'd still be worried that without the router tagging incoming packets for the guest VLAN, I wouldn't have proper segregation between the guest and parish networks.
You don't need to do any setup on your router at all if using Open-Mesh because Open-Mesh AP's are the gateway for the system so no configuration your your part with extra equipment. The Open-Mesh guest network uses an IP of 10.255.251.x with a gateway of 10.255.248.1 its all self handled within Mesh, No special switches needed. It works great.
LoneWolf
I'm using both a Netgear GS110TP and a Cisco SG300-10MPP, part of their small business line.
The GS110TP actually is a managed switch.  Maybe not in the same category as some, but it is managed.  You can set up VLANs, link aggregation, etc.  The price is good, and it has PoE.  My two gripes are that there is no commandline, and that the GUI is slow, something I have found common to Netgear switches.
The SG300 switches are in a completely different league.  They have both a reasonably responsive GUI, and commandline operation using the VxWorks operating system (Dell also uses this in their Powerconnect switches).  It is iOS-like, but not iOS, so not exactly the same, but the commandline is great for learning how to work with switches.  The SG300 line can switch between Layer 2 and Layer 3, which, for the price, is a pretty incredible feature.  Name a feature; the SG300 line supports it, in switches that range between 10 and 52 ports, some with PoE and some not.  Unlike Cisco enterprise switches, no support contract is required for firmware upgrades or technical support.  Performance wins too.  Finally, the SG300 switches are more secure, or at least, can be customized to be so (via SSH or HTTPS access).
Both Netgear and Cisco Small Business have lifetime warranties.  Nothing against HP's ProCurve line or Dell's PowerConnect either, but the ten-port SG300 is probably one of the more amazing values I've seen if you go by features-per-dollar, and even the PoE versions are fanless.  It's also got GBIC ports for fiber like the GS110TP if you want to play with that.
Edited by LoneWolf
    • JROrtiz
      By JROrtiz
    • Jason
      By Jason
      Have been running a Windows DHCP server on home WSE12R2 box for quite some time behind my Sophos UTM firewall. Also allowed me to seamlessly run Windows Deployment Services at home. WDS just worked.
      But if I needed to make a particular LAN IP address exception on the firewall, I had to 1.) create a Windows DHCP server reservations AND 2.) create a network definition for that IP on the Sophos UTM box. 2 steps. Not very efficient; was sure I was doing something incorrectly...
      Tried to migrate to Sophos UTM running the DHCP Server, but now WDS doesn't work. LAN devices can no longer PXE boot. Seems possible. Many guides. None have proven especially successful.
      Is it possible to run a Windows DHCP server and have Sophos UTM import DHCP reservations instead of maintaining 2 unique entries for each IP reservation (one in Windows DHCP, another on Sophos UTM box)?
      What is best practice?
    • donschmidt
      By donschmidt
      Good morning.  I've just  purchased a home still under construction and plan to have CAT6 installed throughout the living areas. I'm hoping that someone can advise me as to the specific quality/specs of cable that I should use.
      Thanks and Happy New Year.
    • Joe_Miner
      By Joe_Miner
      I've been looking at the Intel Compute Stick BOXSTK1AW32SC and was wondering if anyone here has experience with that and if the Intel AC 7265 built into it is backwardly compatible with older N and A,B wifi?
    • heavy21
      By heavy21
      I want to optimize the performance and security of my home network of servers, PCs, laptops printers, smartphones, TVs, etc.  Current network appliances include layer 2 and 3 switches (Cisco small business) and Linksys router.  I’m looking to replace the Linksys with a security (pfSense) router appliance (w/OpenVPN).  I will also be adding security cameras and a NVR to the network.
      The gigabit network is straightforward in structure with all Ethernet connections hanging off the24 port switch connected to the cable modem and router except a cascaded 8 port switch in a room to provide 4 Ethernet connections in a room with only one data port.  Wireless connections presently come off the Linksys but will eventually come off the to-be-purchased security/router appliance with a wireless card.  I don’t see more than 100 devices in total for the whole network.  No VLANS and no sub-netting.  All hardware supports IPv6.
      Hardware line up is:
      Dual Zeon server w/RAID 10 of 24 TB of storage, 64GB memory
      Cisco managed switches layer 2 and 3
      HPEX495 server
      Workstations, Desktops, Laptops, Tablets, iPads
      Printers
      Software line up is:
      Windows Server Essentials 2012 R2, single domain controller, storage and file server duties
      Windows 10 Pro all non-server Intel computing devices
      PLEX server for streaming audio and video to display units
      Office 365
      From what I’ve read so far, it appears that I need to incorporate an IP addressing scheme for clients and servers on the network.  It would also appear that I need to implement VLANS and/or sub-netting to protect access to certain files and security footage, provide guest networking with future consideration for electronic door locks and some sort of server based media distribution to various display devices,
      What are best practices on assigning client and server devices to IP ranges, fixed or dynamic IP addresses?  Do I need to assign clients or servers to IP ranges?  What are the considerations in establishing sub-nets over VLANS or vice versa?  I’m pretty sure I want to restrict access to cameras and their security footage and personal files on my workstation.
      Thanks for any resources and advice provided.
