NetGear Smart vs. Managed vs. Cisco Small Business vs. ?
Andne
I am looking at upgrading my home network some (need a bigger core switch for the panel) as well as am trying to find hardware to add wireless to my church's basement.  So far, I use Netgear smart switches (I have a GS716T, GS110TP, and GS108T) at home and have been quite happy with them.  I tried to split my network into two VLANs a while ago and while it works ok, there's a couple problems, mostly that the media centers aren't happy about not being able to see the WS2012R2 Essentials server.  Also, when I am able to get devices to talk between the VLANs I'm routing through my pfSense router, which probably isn't ideal.
I am thinking I want a core switch that is capable of inter-VLAN routing in order to get wire speeds between the VLANs.  I use a POE-powered Netgear access point, so I need POE power from that switch as well.  This is where I start to get confused.  I have been mostly happy with Netgear so I've been looking at their offerings.  However, it looks like some of the Cisco Small Business (SG300 I think) may be slightly more capable for less or similar cost.  Does anyone have any experience with their equipment?  Does it work pretty well and isn't too crazy to set up?  I seem to find mixed opinions online.  Mostly here I'm asking for recommendations what hardware I should be looking at for what I want to experiment with.
Also, I'm looking for some new equipment for my church, but their needs are a bit simpler I think.  The cable I'm connecting to is terminated in a wall-mounted rack of audio equipment that has 2U empty in it.  I should double check with the guys that installed that equipment (local A/V systems company), but I'm hoping I can use those for a patch panel and rack-mount switch.  I want POE there in order to power the access point (makes it easier to shove up in the ceiling somewhere) and maybe a repeater (160? meter run back to the office, probably ok, but would be more 'correct' to put one in the middle.  There's a good place for one if needed) and would like VLANs so that I can create a guest vs. parish network at some point (I don't want just anyone who rents out the hall to be able to find the WHS 2011 file server), but I'll have to upgrade the main office switch in order to support that as well.  I don't see any reason to need inter-VLAN routing, so I suspect the Netgear Smart switches would be capable enough here.  One challenge I'm having is a lot of smaller switches that I think can do it are not rack-capable.  At the moment, 8 ports is more than enough, probably only need 2-4 in the next couple years.
I suspect it would help my own sanity if I were to use at least the same brand and family of switches in my home network as I use there, so that I don't have to remember how to configure two different systems.  I'm a software engineer by day, not a networking guy, so I don't get much exposure to this stuff otherwise.
Am I completely off base here?  Are there other types/brands of equipment I should be looking at for this?  I saw some Engenius stuff that might meet some needs, but the reviews on it are quite mixed.  It seems to me like I could probably 'make it work' with some really cheap (sub $100 hardware), but I don't feel like that is really a good solution and will probably cause more trouble in the long run.  Now that people know the cable run is done they seem to be getting a bit antsy to have their internet access down there (even though I have no clue what they plan to do with it) and so keep asking me what do we need to finish the project.
For access points have a look at Open-Mesh http://www.open-mesh.com/ Been using them for the past 2 or so years and I have been very happy with them. Also have a look at this thread http://homeservershow.com/forums/index.php?/topic/9901-open-mesh-has-released-there-new-mr1750-dual-band-80211ac-access-point/
and pcdocs review http://thedocsworld.net/mr1750-ac-wireless-access-point/
I am sure others will post as well with recommendations on switches, Ect. I also use several Netgear switches including there NetGear GS724T - 24 Port Managed Switch & Netgear 8 Port Switch (GSS108E) and for the most part been happy with them.
if you are using vlans yet want to interconnect them, I am not aware of a smart switch that would do that. you could perhaps use one of your servers via 'internet sharing' but the whole idea of letting one vlan mix with another seems counter to the intent of the feature....
I know I need a Layer 3 Managed switch to do that.  The intent is to have my servers mostly isolated from the rest of the network, but still allow certain services to connect through to them.  I'm not really sure if it's a valid use for that functionality or not, on a large scale I suspect it's done by using routers to partition the network into subnets, but I really don't want to spend the kind of money I think that would cost me.
I personally think trying to do this they way your thinking is going to get messy at best. What services are you wanting the guest network to have access to? Also will the guest network be WiFi only or both wired/WiFi?
The Layer 3 switch is for my home network, I know that's going to be messy, but that's half the fun of having such hardware at home.
The church network I don't plan to have any inter-VLAN routing on.  My (eventual) plan is two VLANs, both going to the router and out through there.  There's nothing on the church network that the guest VLAN would need access to.  I think that it will be WiFi only to start, there aren't any accessible network jacks in that area.
Sorry for the confusion, I'm looking at upgrades to two different networks with different wants/needs at the same time.
I think for the sake of sanity and for use to give you better advice please make separate threads for each place your trying to solve a problem with so we have a clear understanding of each location and what your trying to accomplish at each location, This will keep the thread neat and clean giving advise only for that location with your intended goal. Wrapping up multiple projects with multiple locations make the thread very messy.
Sorry for the confusion, I'm looking at upgrades to two different networks with different wants/needs at the same time.If the guest
If the guest network is going to be WiFi only at the church then you don't need to create your own VLAN threw the router or switch if you use the great product I told you about for the access point Open-Mesh because Open-Mesh can handle this task for you threw the settings. In fact Open-Mesh even has a LAN port on them that you could connect a regular un-managed switch to and tell Open-Mesh not to allow access to your private LAN but only the guest LAN, This would be just another way to handle what your trying to do.
Edited by itGeeks
The main reason I posted them together is I would like to use same/similar hardware in both locations so that what I learn at home I can apply to the parish network as well.
I would think that the router and switch still need to be aware of the VLAN so that the connections can be routed correctly.  The Open-Mesh hardware may be able to separate out the wireless networks, but how does that isolate the guest wireless from the parish LAN unless the router is also aware.  I suppose the switch could maybe be dumb since it'll just forward the packets along anyways, but I think then I'd basically have every endpoint on the network connected to a trunk port which I assume is not a good thing.  Even if that works and the access point does some filtering, I'd still be worried that without the router tagging incoming packets for the guest VLAN, I wouldn't have proper segregation between the guest and parish networks.
What topology is your network? It sounds like you shouldn't be splitting it if you're getting issues with devices not being happy that they're not on the same subnet as another device.
If you don't need fully managed and static L3 routing is fine then the HP 1910-24G is pretty nice. You get a lifetime warranty on it.
If you only have 1 PoE device then getting a PoE injector will save you a lot of money. If you do want it built into the switch then the HP 1910-24G-POE should be fine unless you need PoE+.
Personally, I've never been that impressed with the managed or smart managed range from Netgear. The interface has always been a bit weird, the CLI has been like a bad Cisco clone and I've had several switches fail in odd ways. Netgear customer support has always been great though. No problems at all getting replacements.
I like the metal cased unmanaged Netgear switches though. No problems at all with them. The metal case makes them very robust and no issues with overheating.
I've never used the Small Business range from Cisco. I've only used the large Catalyst switches from them.
You need to check the depth of the rack. Audio equipment racks tend to be very shallow. The HP switches I've mentioned are all quite shallow but you'll still need to check.
Same again about a PoE injector. It'll save you a lot of money if you can avoid getting PoE built into the switch itself.
HP 1810-24Gv2 is a L2 switch with the same lifetime warranty. The HP 1910-24G is only slightly more expensive though.
HP 1810-8Gv2 for L2 or 1910-8G for static L3. They're little desktop switches. You'll need to make sure nobody fiddles with the wiring though since some ports will be trunk ports. Edited by GotNoTime
That is how I'd do it. The WiFi APs broadcast 2 SSIDs and it is VLAN aware. The main SSID goes to the main VLAN and the guest SSID goes to the guest VLAN. The WiFi AP is plugged into a configured trunk port on your switch. The rest of the switch ports are trunks to other APs or switches and untagged ports assigned to the appropriate VLAN. It is very cleanly separated using standard features with no surprises in the future and the ability to change parts of the system for another model or brand without breaking horribly.
Your router will need to have VLAN support and the ability to have multiple DHCP servers. I assume it'd all be NATed anyway and you don't have any publicly routed IP blocks.
Edited by GotNoTime
    • JROrtiz
      By JROrtiz
    • Jason
      By Jason
      Have been running a Windows DHCP server on home WSE12R2 box for quite some time behind my Sophos UTM firewall. Also allowed me to seamlessly run Windows Deployment Services at home. WDS just worked.
      But if I needed to make a particular LAN IP address exception on the firewall, I had to 1.) create a Windows DHCP server reservations AND 2.) create a network definition for that IP on the Sophos UTM box. 2 steps. Not very efficient; was sure I was doing something incorrectly...
      Tried to migrate to Sophos UTM running the DHCP Server, but now WDS doesn't work. LAN devices can no longer PXE boot. Seems possible. Many guides. None have proven especially successful.
      Is it possible to run a Windows DHCP server and have Sophos UTM import DHCP reservations instead of maintaining 2 unique entries for each IP reservation (one in Windows DHCP, another on Sophos UTM box)?
      What is best practice?
    • donschmidt
      By donschmidt
      Good morning.  I've just  purchased a home still under construction and plan to have CAT6 installed throughout the living areas. I'm hoping that someone can advise me as to the specific quality/specs of cable that I should use.
      Thanks and Happy New Year.
    • Joe_Miner
      By Joe_Miner
      I've been looking at the Intel Compute Stick BOXSTK1AW32SC and was wondering if anyone here has experience with that and if the Intel AC 7265 built into it is backwardly compatible with older N and A,B wifi?
    • heavy21
      By heavy21
      I want to optimize the performance and security of my home network of servers, PCs, laptops printers, smartphones, TVs, etc.  Current network appliances include layer 2 and 3 switches (Cisco small business) and Linksys router.  I’m looking to replace the Linksys with a security (pfSense) router appliance (w/OpenVPN).  I will also be adding security cameras and a NVR to the network.
      The gigabit network is straightforward in structure with all Ethernet connections hanging off the24 port switch connected to the cable modem and router except a cascaded 8 port switch in a room to provide 4 Ethernet connections in a room with only one data port.  Wireless connections presently come off the Linksys but will eventually come off the to-be-purchased security/router appliance with a wireless card.  I don’t see more than 100 devices in total for the whole network.  No VLANS and no sub-netting.  All hardware supports IPv6.
      Hardware line up is:
      Dual Zeon server w/RAID 10 of 24 TB of storage, 64GB memory
      Cisco managed switches layer 2 and 3
      HPEX495 server
      Workstations, Desktops, Laptops, Tablets, iPads
      Printers
      Software line up is:
      Windows Server Essentials 2012 R2, single domain controller, storage and file server duties
      Windows 10 Pro all non-server Intel computing devices
      PLEX server for streaming audio and video to display units
      Office 365
      From what I’ve read so far, it appears that I need to incorporate an IP addressing scheme for clients and servers on the network.  It would also appear that I need to implement VLANS and/or sub-netting to protect access to certain files and security footage, provide guest networking with future consideration for electronic door locks and some sort of server based media distribution to various display devices,
      What are best practices on assigning client and server devices to IP ranges, fixed or dynamic IP addresses?  Do I need to assign clients or servers to IP ranges?  What are the considerations in establishing sub-nets over VLANS or vice versa?  I’m pretty sure I want to restrict access to cameras and their security footage and personal files on my workstation.
      Thanks for any resources and advice provided.
