Hyper-V vs VMWare - What Virtualization platform for me to use?
hyper-v vmware server virtualisation platform comparison home beginner
  • Please log in to reply
67 replies to this topic
#21 no-control
no-control
    HSS Elite
  • BYOB Podcasters
  • 1,754 posts
  • LocationSoCal
Posted 17 February 2012 - 10:17 AM
Clarification on a few of your findings.
Hardware - You will want to run either platform on relatively recent and powerful hardware. More RAM is good. Make sure the hardware CPU/mobo is VM capable. run on anything is really a valid statement. You want it to run well.
HW access - Hyper-V allows direct access to SATA ports and GPUs. ESXi allows pass through of PCI and USB
Storage limits - Hyper-V .vhd are limited to the 2TB limit as well. But with pass through you can attached large arrays without issue
Outstanding questions
  • Depends on how well you can navigate and learn a different GUI and relate to language to what you're already familiar with. some people can move seemlessly between windows, linix and OSx....some can't. Being that you aren't familiar with Hypervisors in general the curve will steep regardless. One feels like windows the other feels like a web page
  • Correct but if all you need is for it to sit on an existing network it's fairly easy. If you are going to try and run multile networks inside a single hypervisor then it helps to have a basic understanding of how it parses out the physical from the virtual
  • Most Hypervisors are the same in general its the details that differ
  • for USB back up in Hyper-v all you do is attach the stroage as another SCSI controller and present it to the guest via passthrough. It works fine that way.
  • No it must run baremetal
  • no idea never tried sorry
  • No, but again I haven't used VMware in over 2 years
  • I'm pretty sure there is a setting for that.
Edited by no-control, 17 February 2012 - 10:17 AM.
VISIT MY NEW BLOG
Main Rig - i3-3225, H60, ASRock H77 mITX, 8GB G.Skill RJX, R6970 Lighting, 256GB M4 SSD, WD 500GB, Seasonic x650, CM Elite 210, Dell U3011 w/ 2x 2007fp PLP - W7 -|-
HTPC - G620, Big Shuriken, ASRock H77M , 4GB OCZ, 128GB G.Skill Falcon, .5TB WD CB, Sony BD-R, Corsair CX400, LianLi C37B - W7 -|-
VM Server - i3-3220, Z77-D3H, 32GB G.Skill, 250GB OS, 3x3TB WD GP R5, 4x300GB WD VR R0, Corsair CX430, Fractal R3 - WS2012 -|-
Lenovo Yoga 13 | Surface RT | HTC Titan
Find me on the internet
#22 pcdoc
pcdoc
    HSS Legend
  • Moderators
  • 3,563 posts
  • LocationLos Angeles, California
Posted 17 February 2012 - 12:37 PM
Hi, after the first few rounds of questions and answers, I have gotten the following understanding, which to some smaller or larger degree might be wrong – so please correct me
However there are still some unaswered questions (at end) that I have, in addition to any misunderstanding in the first section.
Platform requirements
  • Hardware
  • Hyper-V: Runs on almost anything
  • VMWare: Picky and one need to check
  • My conclusion: My HW is very close to the one used by Tinkerguy, so any platform should work
Client HW direct access
  • Hyper-V: NO (although pass through of storage, including USB). However, there is some sort of access through RemoteFX - but I am still trying to figure this one out fully.
  • VMWare: USB storage: OK; PCI direct access: unknown
  • My conclusion: USB direct access for back-up could be useful in the long term, but the real important one is PCI-direct access.
Storage limits
  • Hyper-V: unknown, so far
  • VMWare: 2tb limit on HDD?, but RAID (one volume) can be any size. However 2YB limit can be partly circumvented by ISCSI or RDM
  • My conclusion: VMWare is more complicated to set up
Hypervisor installed size:
  • Not an issue – but VMware small size – load on thumb drive – does open up interesting possibilities for this and my old WHS v1 box (if the old atom board is compatible)
Client OS
  • Hyper-v will be the easiest and most compatible with the guest VMs (see initial post)
Outstanding Questions
  • If one is used to Windows environment, ESXI has a farly steep learning curve but how steep??
  • How complicated your networking portion is Hyper-V may have a steep learning curve.
  • How is the general logic/structure of tools/menus differ?
  • With Hyper-V USB back-up could be problematic, but I have read somewhere that RDP could help with USB, or is this wrong?
  • Can I run ESXI on Server 2008 R2 instead of Hyper-V, or must I run it "bare bone"?
  • Direct backup of entire drive in ESXI (as in Hyper-V), is it doable?
  • “VMs safe state” at back-up in Hyper-V. Is there anything like it in ESXI?
  • ESXI goes into power saving mode that shut sdown VMs– is this a solvable problem?
1. The "basic" setup is pretty straight forward. Beyond that is gets a bit crazy. Not so much that it is hard but rather very confusing. Especially with the variety of add-ons or utilities. There are also a bunch of settings. You will get there but I would say it is about 5-10x more complicated to setup than Hyper-V.
2. There is too many to list. there are very different.
3. If backup is you only concern, there are work arounds for that . IP to USB, eSata, NAS.
4. Nope. Barebones but since it boots from a USB stick you can easily setup in a test enviorment.
5. Not without an expensive third party backup. You can backup the VM however.
6. ?
7. Absolutely, power settings are both VM and server based (different settings of course)
Main Server - WHS 2011, Core I5-2500, 12T RAID 5 (5x3T) + 2T of Mirror + 2T of backup
Second Server - 2008R2, Core I5-2500, 12T RAID 5
Main Systems - Core I7-2600k, 16 Gigs DDR3-1600, 180 Gig Intel 330 SSD Max IOPS 240 Gig Vertex 3, 2T Sata 3 for local Backup
Other systems - Core I7-2600, Core I3-530's, Core I5-2500, Core I7-920, Core I3-2100, and G620 (see System List)
My Blogs - The Docs Blog and Tablet Resource
BYOB Videos - TheBYOBPodcast
For a complete system List: Computer Systems
#23 Server Grunt
Server Grunt
    HSS Star
  • Members
  • 74 posts
  • LocationSweden
Posted 18 February 2012 - 03:42 PM
I must confess that the differences between pass through and direct access are unclear, I.e. what does thy men in practice for USB devices (hdd, cameras, mouse, keyboard, card readers etc., PCI-cards ( raid controllers, graphics cards etc.) and GPU performance?
Also, as I understand from various reeds, there is a ideal set up to have a 1:1 ratio between NIC and VMs. However, is it better if these are physical NICs or not? My Mobo has two NICs - should I get a server card like the HP NC375T PCI Express Quad Port Gigabit Server Adapter or?
/Grunt
#24 no-control
no-control
    HSS Elite
  • BYOB Podcasters
  • 1,754 posts
  • LocationSoCal
Posted 18 February 2012 - 05:04 PM
Passthrough and direct access mean the same thing.
The 1:1 NIC to VM is for novices to keep it simple. This is fine if you have a nice big switch. The whole point of VM is to virtualize. This includes the network. I Have had anywhere from 1-4 NICs in my VM box, depending on the project. I'm back down to using just a single NIC for my VMs. My Preference is a 1:1 ratio of NIC to Networks.
VISIT MY NEW BLOG
#25 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,565 posts
Posted 19 February 2012 - 09:58 AM
That said, more physical NICs in a VM box will improve overall network performance to the VM box, will it not?
If at first you don't succeed, do it like your mother told you.
#26 jmwills
jmwills
    HSS Genius
  • Donating Member
  • 5,113 posts
  • LocationHuntsville, AL
Posted 19 February 2012 - 10:21 AM
One NIC per virtual network (VLAN) is desired. I am running 5 VM's on the single NIC right now. No issues.
Windows 7 Desktop - Antec 100 Case, Intel D8H67BL, OCZ 550W PSU, Intel i3-530 CPU w/16GB G-Skill DDR3 1333 RAM
Server 2012 - Fractal Arc Midi, CoolerMaster M600 PSU, ASUS P8H67V, Intel i5-2500 CPU w/32GBG-Skill DDR3 1333 RAM, 90 GIG OCZ SSD OS Drive – Roles: Hyper-V (WHS-SharePoint-DC-SQL-Exchange-WSE 2012), Print Server - Rocket RAID 2720 5x2TB
HTPC Build - Silverstone GD05 Case, ASUS P7H55-M PRO, CoolerMaster M600W PSU, Intel i3-530 CPU w/4GB G-Skill DDR3 1333 RAM. OCZ 60GB SSD Drive for the OS with a 120GB WD 2.5" Blue drive for data storage.
Travel Laptop: Dell XPSL502X 15.6"
#27 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,565 posts
Posted 19 February 2012 - 10:50 AM
Just wondering, have you tried streaming blu-ray from 2 or more of the VMs simultaneously?
#28 no-control
no-control
    HSS Elite
  • BYOB Podcasters
  • 1,754 posts
  • LocationSoCal
Posted 19 February 2012 - 11:06 AM
No its no different than a physical box. If you're not saturating the NIC there is no need for more. Primary reason for multiple NICs is to assign static IP to that NIC. For a networking usually you have each network on a different NIC so if one goes bad you do not lose the entire company. Just that portion of the network. It also makes network configuration changes easier. If you are saturating a GigE NIC then you have bigger issues and would need to upgrade to 10gb or Fiber.
Streaming from VM to VM isn't really going to load anything much since it would never touch the switch. Streaming over the netowrk? Yes, I've streamed at least 3 BD rips on my network without issue.
VISIT MY NEW BLOG
#29 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,565 posts
Posted 19 February 2012 - 12:43 PM
cool. Nice to know the headroom is there if I ever want it.
#30 KrisseZ
KrisseZ
    HSS Star
  • Members
  • 86 posts
  • LocationFinland
Posted 22 February 2012 - 08:42 AM
Since I'm feeling energetic today I want to input even though it might not be necessary.
I think that the ESXi is very simple and easy to use. You don't even need the guides, since the GUI is so easy to use (via vSphere ofc).
Now if you'd want to setup a VMware HA cluster with DRS on, oh that's an other story.
But a single ESXi machine is fairly straightforward to use. And regarding the 2 Tb limit this may be of some help.
VMFS-5 Enhancements
Large Single Extent Volumes. In previous versions of VMFS, the largest single extent was 2TB. With VMFS-5, this limit has been increased to ~ 60TB.
And since ESXi is capable of VMFS-5 datastores I guess no probies?
[Hydrabox] Windows 7 Ultimate - Intel Core i7 920 @ 3,8 Ghz - Asus P6T Deluxe - 12 Gb 1600 Mhz DDR3 - Intel X25M G2 160 Gb - 2x1 Tb WDM @ Raid 0
[Khronos] Windows 2008 R2 - AMD Athlon II X 2 250 - ASrock N68C-S UCC - 4 Gb 1333 Mhz DDR3 - RR2680 with no proper disks yet. - 4x 3 slot sata backplane
#31 bitleague
bitleague
    HSS 1 Post Wonder
  • Members
  • 8 posts
Posted 25 February 2012 - 12:54 PM
I have been running an ESXi server at home for a couple of years now.
Ran WHS v1 on there and now am running WHS 11 on the server (along with a Win7).
I've also been running it off of a USB drive with no issues. Like stated before it frees up a drive .
#32 thobel
thobel
    HSS Star
  • Members
  • 93 posts
  • LocationNYC
Posted 25 February 2012 - 07:56 PM
Can anyone point me to directions on USB passthrew on Hyper V?
I have 2008R2 with Hyper V running WHS 2010 Its only used for client backups and remote access (rdp) I would really feel better with server backup running on the WHS unless someone can point me to a better solution? (snap shots?)
Main Rig: Danger Den Cutom DoubleWide, Asus R3E, Intel 980x, 6GB Super Talen DDR3 2133 (Hypers), 3x Intel X25MG2 160's in Raid 0, 3x GTX580's Full Water Cooled 120.18 of Rads
Backup Main: Corsair 800D Asus R3E, Intel 980x, 12GB Corsair Dominator GT DDR3 1866, 3x Intel X25MG2 80GB's in Raid 0, 3x GTX480's Full Water Cooled 120.5 of Rads
WHS: Lian Li PC-A71F, Asus P8P67-Pro, Intel 2600K, 16GB Corsair Vengence DDR3 2133, 15x Hitachi 2TB, Areca-1261ML Raid Controller, Asetek 570LC CPU Cooler, OS 2x Ocz Vertex 3 in Raid 0
HTPC: Corsair 500R, Asus P8Z67, Intel 2700K, 8Gb G.Skill DDR3 2133, OCZ Vertex 3 120GB, 2x GTX550TI, Corsair H100
#33 pcdoc
pcdoc
    HSS Legend
  • Moderators
  • 3,563 posts
Posted 25 February 2012 - 10:37 PM
To the best of my knowledge, you can not pass-through USB in Hyper V. The only way I know of is the use of USB to IP adapter. You can however pass through a Sata device.
#34 thobel
thobel
    HSS Star
  • Members
  • 93 posts
  • LocationNYC
Posted 26 February 2012 - 02:26 AM
will whs see the usb drive as a backup device if set threw a usb to ip adapter? If so can yo provide a link to one?
#35 pcdoc
pcdoc
    HSS Legend
  • Moderators
  • 3,563 posts
Posted 26 February 2012 - 03:01 AM
I have not used one but Welchworks and TimeKills have. Here is one link I could find from Greg.
http://www.amazon.co...P/dp/B0024G48MY
#36 jmwills
jmwills
    HSS Genius
  • Donating Member
  • 5,113 posts
Posted 26 February 2012 - 07:23 AM
Interesting looking device. Hmmmmmmm
#37 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,565 posts
Posted 26 February 2012 - 08:28 AM
That is a waay cool device, and it's pretty cheap too.
#38 no-control
no-control
    HSS Elite
  • BYOB Podcasters
  • 1,754 posts
  • LocationSoCal
Posted 26 February 2012 - 10:58 AM
this is correct in order to pass through a USB drive. You need to take it offline in the Host, then add it as a SCSI drive (like SATA Passthrough). If you want to retain USB type functionality you'll need a network USB device like PCDoc mentioned.
VISIT MY NEW BLOG
#39 Server Grunt
Server Grunt
    HSS Star
  • Members
  • 74 posts
  • LocationSweden
Posted 27 February 2012 - 07:46 AM
Ok
Let me try to get this right:
PCI-cards (i.e. NIC & GPU cards)
Hyper-V: Will allow VMs Pass-through for full utilization like it would be in a normal PC set-up
VMware: Will allow VMs Pass-through for full utilization like it would be in a normal PC set-up
DVD/Blu-Ray
However: Ripping in a VM will not work (not completely clear why, though)
HDDs
USB
Hyper-V: Will NOT allow VMs Pass-through for full utilization like it would be in a normal PC set-up
However: Using ethernet/eSATA/(i)SCSI a USB device could be directly accessed by a VM
Question: Am I right to assume that this does not apply for USB keyboards and mouse.... Is this because they for all intent an purposes are used through the Hyper-visor virtually when actually accessing the VM, or?
Also, found this SW based USB access - anyone that knows anything about it?
http://www.virtualserialport.com/products/usb-over-network/?gclid=CK3sp-2dvq4CFYYXzQodMXZd8g
#40 pcdoc
pcdoc
    HSS Legend
  • Moderators
  • 3,563 posts
Posted 27 February 2012 - 01:21 PM
You have summarized it well. The keyboard mouse stuff is handled when you RDP into the machine. ESXi uses proprietary drivers and Hyper-V uses default MS drivers. As for the link, I am not familiar with it but I would not use a software solution for something important.
Also tagged with one or more of these keywords: hyper-v, vmware, server, virtualisation, platform, comparison, home, beginner
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
