System Drive Failing Saga
whsv1 system drive failing swap
  • Please log in to reply
51 replies to this topic
#21 dvn
dvn
    HSS Elite
  • Moderators
  • 1,633 posts
Posted 02 January 2012 - 04:58 PM
Just to double check on Server Restore, does it or does it not wipe your PC backups?
There are ways around this if so, but I want to make sure foy1der doesn't have an unpleasant experience. :)
  • Rich's Random Podcast Generator
  • Desktop - i7-2600K | ASRock Z68 | 128GB Crucial RealSSD C300 | Cooler Master Silent Pro 600W | Lian Li K60B case
  • VM Server - Q9550 | Gigabyte EP45T-USB3 | 2 x 4 GB DDR3 1333 | Lian Li KB60
  • HTPC - Revo 3610
  • WHS 2011 - Core i3-540 system | Lian Li K60B case
  • HP MSS EX495
#22 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,546 posts
Posted 02 January 2012 - 05:25 PM
Dang, wish I could remember for sure. I seem to recall that Server Recovery does retain the backups, but a full Server Restore does not.
It needs to be mentioned, again, that it's important to uninstall the WHS Connector from the computer that will be running the Server Recovery.
If at first you don't succeed, do it like your mother told you.
#23 Joe_Miner
Joe_Miner
    HSS Elite
  • Moderators
  • 1,720 posts
  • LocationCentral Illinois
Posted 02 January 2012 - 05:59 PM
Yes, the bad drive is WD Black, carries a 5 year warranty. I think it runs out in like 2014. So I'll be getting it replaced.
WD has a VERY generous RMA policy for "bad" drives -- for ~$6 each I got replacements for several failing drives and did the whole thing online and in each case ended up with a new drive that was better than what I had before -- for a WD20EADS they'd send me a WD20EARX -- nice!
Unfortunately, I got a lot of experience with Server Recovery and Server Reset. http://homeserversho...l-out-on-ex487/
Server Recovery will not save your BDBB that was on your old System Drive -- usually the BDBB is spread across all of the drives -- it can be recovered before hand but you'll need to do the procedure manually described in the MS White Paper that the pgm BDBB is based on. Google the wiki that describes BDBB -- in the notes there's a link to the white paper --
http://www.mediasmar...ex.php/WHS_BDBB
http://download.micr...nd_Restore.docx
Server Recovery does save all your shares but the PC backups will be toasted.
Server Reset destroys everything and starts out fresh.
FYI: There is a paper on how to do a Sysdrive Cloning at http://www.mediasmar...s-system-drive/
WHS-V1: HP EX-487: 4*WD20EARX, Athena AP-MFATX30, 4GB G.Skill, E5200, Stablebit Scanner-|-
WHS-2011: HP N54L G7, Kingston ECC 8GB KVR1333D3E9SK2/8G, OS: 256GB M4, 5*ST3000DM001, WD PCIe USB3, R640L, Stablebit DrivePool & Scanner -|-
Test Labs: HP N40L, G.Skill 16GB F3-1333C9D-16GAO, rr2720 -|- HP N40L, Kingston ECC 16GB KVR1333D3E9SK2/16G -|-
S2012 Hyper-V Lab: Lian-Li K9WX, GA-Z77X-UD5H, i7-3770, 32GB G.Skill, 240GB Corsair GT + various HDD's-|-
Desktop W8P64: HAF 932,GA-X58A-UD3R,i7-930,12GB,240GB Corsair GS + various HDD's,HD5850,Samsung Series9 & 213T+Planar PX2710MW,C920 -|-
HTPC3 W8P64WMC: GD05B, GA-Z68MX-UD2H-B3, i5-2500K, 16GB G.Skill, Corsair GTX 240GB, Crucial M4 256GB , C910, Camtasia-|-
Laptop W8P64WMC: Acer 1810T, 4GB RAM, 240GB Corsair GT SSD-|-
#24 dvn
dvn
    HSS Elite
  • Moderators
  • 1,633 posts
Posted 02 January 2012 - 06:31 PM
If that's the case, and the old drive still works, put it back in and run BDBB. Done deal.
  • HTPC - Revo 3610
  • HP MSS EX495
#25 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,546 posts
Posted 02 January 2012 - 06:53 PM
Thanks Joe_Miner. I was afraid I was recalling it wrong, and I was, so your clarification is great.
If you want to retain the backups then definitely try to back them up before doing the Recovery.
#26 foy1der
foy1der
    HSS Pro
  • Members
  • 180 posts
Posted 22 February 2012 - 08:07 PM
I wanted to fill you folks in on how my server repair is going. I have finally gotten moved into my new house and I have slowly been rebuilding the server. I ended up buying a new hard drive in order to make shifting the data around a little easier. I bought a 2TB WD Black.
So I initially tried installing WHS 2011 but that install didn't complete. I switch back to version 1, but that install wouldn't complete as well. I started getting curious about hardware so I ran Memtest. Knowing that memtest could take a while, I started the test and stood up from my desk chair. By the time I had finished standing up, Memtest had found 125 errors in my ram. After running for an hour, it was up to 20k errors (I think I found the issue). So I swapped out the ram and ran the test again to make sure it wasn't the DIMM slots.
I have also not been able to reproduce the errors that WHS was finding in the system hard drive. I will just connect that one to the server and wait for it to fail, I guess.
With fresh ram, the WHS version 1 install went very well. However I still have one issue. My notebook will not complete the WHS Connector install. When I install the connector, I get a message that I need to update the connector software (see attached). When I go through the motions to complete this process, I get an error that "This operation cannot be completed at this time". I'm hoping that someone else might have encountered an issue similar to this. I have also attached a screenshot of the failure message.
Posted Image
Posted Image
#27 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,546 posts
Posted 22 February 2012 - 08:20 PM
Have you tried installing by browsing to http://<servername or IP>:55000 ??
#28 foy1der
foy1der
    HSS Pro
  • Members
  • 180 posts
Posted 22 February 2012 - 08:29 PM
I forgot those interesting details. When I try doing that, I get an error that the page cannot be found. When I ping "server" it fails to find the server. When I ping the server's IP address, I get a response. When I navigate to "192.168.0.190:55000" I get the connector home page. Lastly, when I download the connector install, I get the "This operation cannot be completed at this time" error.
I hope all of this isn't too confusing. Perhaps I should have made a flow chart.
#29 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,546 posts
Posted 23 February 2012 - 07:44 AM
OK, so DNS is not working on your LAN - that's one issue, but not critical to getting the connector installed. Have you tried downloading the Connector installer to your client computer and running it locally?
#30 foy1der
foy1der
    HSS Pro
  • Members
  • 180 posts
Posted 23 February 2012 - 07:58 PM
The only way I was able to get this far was to download the connector install on a different computer and install it from a USB stick. I should also note that on my desktop was able to install the connector software properly and it is running backups. The desktop can also ping "server" properly.
#31 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,546 posts
Posted 24 February 2012 - 07:27 AM
OK, stupid question: you did uninstall the Connector before trying to install it again, right? Like I said stupid question, but just to cover all the bases :)
#32 foy1der
foy1der
    HSS Pro
  • Members
  • 180 posts
Posted 24 February 2012 - 07:37 AM
No it's not a stupid question, I have indeed uninstalled the connector before trying to install the software.
Sent from my DROIDX using Tapatalk
#33 jmwills
jmwills
    HSS Genius
  • Donating Member
  • 5,108 posts
  • LocationHuntsville, AL
Posted 24 February 2012 - 07:55 AM
Map a shared drive over to the server
\\servername\C$ or \\ipadress\C$
and go to the software folder. The connector is in there and yes you need to remove the old connector.
Windows 7 Desktop - Antec 100 Case, Intel D8H67BL, OCZ 550W PSU, Intel i3-530 CPU w/16GB G-Skill DDR3 1333 RAM
Server 2012 - Fractal Arc Midi, CoolerMaster M600 PSU, ASUS P8H67V, Intel i5-2500 CPU w/32GBG-Skill DDR3 1333 RAM, 90 GIG OCZ SSD OS Drive – Roles: Hyper-V (WHS-SharePoint-DC-SQL-Exchange-WSE 2012), Print Server - Rocket RAID 2720 5x2TB
HTPC Build - Silverstone GD05 Case, ASUS P7H55-M PRO, CoolerMaster M600W PSU, Intel i3-530 CPU w/4GB G-Skill DDR3 1333 RAM. OCZ 60GB SSD Drive for the OS with a 120GB WD 2.5" Blue drive for data storage.
Travel Laptop: Dell XPSL502X 15.6"
#34 jazzerjay
jazzerjay
    HSS Champion
  • Members
  • 359 posts
  • LocationPhoenix, AZ
Posted 24 February 2012 - 08:46 AM
This is a fantastic thread. Foy1der, you are a rock in my opinion, I would have probably thrown things out the second floor window by now.
#35 foy1der
foy1der
    HSS Pro
  • Members
  • 180 posts
Posted 24 February 2012 - 09:24 AM
One of the only things that I haven't tried yet (should have been first) is to try a wired connection.
#36 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,546 posts
Posted 24 February 2012 - 11:25 AM
Good idea.
#37 foy1der
foy1der
    HSS Pro
  • Members
  • 180 posts
Posted 24 February 2012 - 08:11 PM
Here are the steps I took to fix the issue:
1. Consume (at a minimum) two hop infused adult beverages.
2. Connect laptop to a wired ethernet connection.
3. Install connector software.
4. Ask "Why didn't I do this last week?"
Thanks for all the tips guys, I think we can mark this issue closed.
Probably not though, I'll wait for a couple days of backups to run first. ;)
#38 jazzerjay
jazzerjay
    HSS Champion
  • Members
  • 359 posts
Posted 24 February 2012 - 09:08 PM
Do not...I repeat, DO NOT smack your head before you have the beverages. Good luck dude...again, can't wait to hear how this turns out for you.
#39 ikon
ikon
    HSS Genius
  • Donating Member
  • 8,546 posts
Posted 25 February 2012 - 08:28 AM
Agreed, not before you consume the beverages - do it after; if you've had enough of them you won't feel it ;)
#40 foy1der
foy1der
    HSS Pro
  • Members
  • 180 posts
Posted 25 February 2012 - 01:42 PM
OK, the beer didn't help. Well, it helped but it didn't really help. I was able to get the connector to install without too much trouble last night. After I unplugged the wired connection, I let the computer stay on over night (on a wireless connection) and it didn't create a backup.
Something that I just noticed: in the Network and Sharing Center, it says that I am connected to my new wireless SSID (Undercover Police Van #9). BUT! The desktop shows that it is connected to the old network name (Undercover Police Van #4). I feel that part of this might be some of the problem. For instance, while on a wired connection, I was able to RDP into the desktop. After trying this over wireless, I got the same errors that I had been getting earlier.
Interestingly, I cannot connect to the server using the connector software (on wired or wireless connection). I'm grasping at straws at this point.
Also tagged with one or more of these keywords: whsv1, system drive, failing, swap
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
